Flash Programer for S12 series
2,335 次查看
YANG-NMOG
Hello:
I am a engineer in the factory in China, we need to produce a new manufacture with use the MCU of S912ZVM.
For my job,I need to design a new automation-machine to do this. Could I get some advice of which Flash Programer can be used in my automation-machine?
I need to design a software to PC to  control the Flash Programer for the automation-chine.
So I need the Flash Progarmer have the API or SDK or other some thing to control
I think is U-MULTILINK-FX,but not sure.
Thank you !
2,323 次查看
ArchieLuo
可以使用Cyclone LC 或者 Cyclone FX,这两个工具是可以脱机烧录的,一般量产都会用这个工具。
U-MULTILINK-FX只是个调试器,必须连电脑使用。
可以使用PROGS12ZZ这个软件,搭配下载器使用。
如有疑问可以联系我~
2,307 次查看
dianabatrlova
Since we have no solution for mass production such as stand-alone programmers, you have to turn to third-party products.
I can confirm the information posted by lsssssssssss.
You can use PEmicro’s USB Multilink Universal FX
http://www.pemicro.com/products/product_viewDetails.cfm?product_id=15320143&productTab=1
"NOTE: For production usage, see the Cyclone LC and Cyclone FX stand-alone programmer, test & debug interfaces."
You can also look at the list of PE micro products for more details about the available debug probes/ flash programmers, see http://www.pemicro.com/products/product_processor.cfm
Diana
2,324 次查看
ArchieLuo
如有疑问可以联系我~
2,281 次查看
YANG-NMOG
谢谢您的回复!
