ECT Function of priority?
1,731 次查看
Kr_Blue
Hi.
Enhanced Capture Timer (ECT) function of the IOS 0 ~ 7 channels with the highest priority?
1,178 次查看
kef
Specialist I
Do you mean which ECT channel has highest interrupt priority? By default higher interrupt priority have interrupts with higher interrupt vector address. Among ECT channels, channel 0 has highest vector address and highest interrupt priority. On S12 you can specify highest priority interrupt using HPRIO register. On S12X you can adjust interrupt priority levels for all interrupts using INT_CFADDR and INT_CFDATAn registers.
1,179 次查看
kef
Specialist I
1,178 次查看
Kr_Blue
Thank you for you'r answer.
