CAN bus connection for 4-different-GND boards
1,506 次查看
aaronlee
I have a new project. I want to using S12ZVCA on each board. These board have different GND. May I using CANPHY on this project?
Aaron
标记 (4)
1,303 次查看
danielmartynek
Hi Aaron,
I’m afraid this will not work, the CANH/CANL needs a common ground between the nodes.
You can use a galvanically isolated CAN transceiver, such as TJA1052i.
1,304 次查看
danielmartynek
Hi Aaron,
1,303 次查看
aaronlee
Dear Daniel,
Thank you very much.
Aaron
