Maybe your reference is wrong ?:smileyhappy:
Am joking - we know the sensor measurements into the kit are not accurate.
That's because the temperature and humidity measured are the ones into the package and are not reflecting 'ambient'
This is also true for air quality and light measurement by the way.
Air is not ciruclating properly into the kit (we wanted to keep it small to develop application)
Light is coming through a hole and is impacted by LEDs into the kit.
For the temperature, we removed an offset (7°) as the self heating (assuming the micro always run at max clock) is repeatable - you would notice a stabilization time assuming you plug a kit whose battery was depleted.
For humidity we did not take any compensation measure as we did not had a proper way to calibrate the humidity measurements vs reality.
