Rapid IoT is not recognized as USB device
3,327 次查看
ccailean
Rapid IoT is not recognized as a USB device. Before that there was a programming incident. Cannot restore factory default with hardware key an SW2.  The left led stays blue.
标记 (1)
3,274 次查看
vicentegomez
Please try to perform all the recommendation that are mentioned on the next thread
https://community.nxp.com/message/1208537?commentID=1208537#comment-1208537
I hope this will help you.
Vicente
3,259 次查看
ccailean
I regained the control over the Rapid IoT, forcing a hardware programming procedure (SW3 + hardware key) instead of a factory reset. At least Windows recognize it as a USB device and I have again the possibility to program the kit.
Thank you.
Corneliu.
Sent from Mail for Windows 10
