No available probes when debugging Rapid-IOT in MCUExpresso
wenchen-b37495
I had the Rapid-IOT kit connected to the laptop via the USB cable. And I was trying to launch the debug session of a Rapid-IOT program in MCUExpresso. However, I was getting the following message saying that no compatible probes available.
What would be the problems here? I looked at the User Guide and it mentioned something about the Docking station shipped by MikroElektronika. Is the docking station necessary for debugging in MCUExpresso?
Tags (2)
estephania_mart
It is necessary to have the docking station in order to debug.
I'm sorry for the inconveniences this might cause you.
Estephania
wenchen-b37495
Thank you for the clarification!
jefflfree
Alternatively, you can use J-Link EDU Mini debugger with the rapid-iot adapter board. You don't have to have a docking station to debug.
