I'm at a trade show, demonstrating Rapid IOT prototyping kit.
I'm charging up the unit over USB.
When it is fully charged, I want to turn it off, and go to sleep.
In the morning, I want to go to the booth to demonstrate the kit.
How do I turn off the unit (without the docking station)??
Solved! Go to Solution.
Mark, There is no "off" switch on this version of the Rapid IoT so you cannot turn it off unless you mount it on the docking station and turn the Docking station off
Keep it plugged in to your laptop when you sleep - that way it will stay charged, or charge it up for a few minutes in the morning prior to your demo. I've demo'd Rapid IoT at multiple trade shows and not found this to be an issue
