I was unable to read TVOC and CO2 in one Project. How do I have to change the weather station project to show a CO2 tab after the TVOC tab?
You need to add a new LabeledIconElement and connect it with CCS811 Air Sensor. Then choose CO2 Read.
I as well made a change in the embedded view to be able to pass CO2 readings.
You can import my project my-air/My Air.atmo at master · vlasov01/my-air · GitHub and look into details how it is implemented.
