How do I get back the default out-of-box- app?
Search instead for
frakman
I just got my device and went through the Getting Started demo and made my first application:
Getting Started with NXP Rapid IoT
Now how do I get back the original app that came with the unit? The one with the Settings, Info, Applications pages that let you try out all the various sensors.
Regarding the list under the left panel entry "Devices":
Do these represent the actual device or the last firmware I downloaded? I ask because when I had to make a tweak to my app and downloaded the new firmware, I didn't see the change reflected in my dashboard so I had to add a new "Device" in order to see the update.
Thank you
theophileleroy
You can also recover default binary by going through application binary recovery process of K64F:
Recovering k64f & kw41z applications binaries
frakman
I found it under the "Studio" tab on the left, then the "EXAMPLES" tab in the middle of the page. Under "EXAMPLE PROJECTS" -> "Rapid IoT Kit Out Of Box Demo"
