Edgex
Edgex
946件の閲覧回数
Devendra1
Hi All,
We are trying to integrate meta-edgex layer to imx6 board, getting the errors related to the go language. currently we are working with the yocto 3.4(Honister) and edgex release fuji, i am new to the edgex and go language, didn't get much help from any forum.
Please let us know if any one done this activity for imx boards irrespective of yocto& edgex version
Please provide your comments on this, attaching the erro msg.
Log data follows:
| DEBUG: Executing shell function do_compile
| NOTE: make -j 20
| CGO_ENABLED=0 GO111MODULE=on go  build -ldflags "-X github.com/edgexfoundry/edgex-go.Version=1.1.0" -o cmd/config-seed/config-seed ./cmd/config-seed
| CGO_ENABLED=0 GO111MODULE=on go  build -ldflags "-X github.com/edgexfoundry/edgex-go.Version=1.1.0" -o cmd/export-client/export-client ./cmd/export-client
| CGO_ENABLED=1 GO111MODULE=on go  build -ldflags "-X github.com/edgexfoundry/edgex-go.Version=1.1.0" -o cmd/export-distro/export-distro ./cmd/export-distro
| CGO_ENABLED=0 GO111MODULE=on go  build -ldflags "-X github.com/edgexfoundry/edgex-go.Version=1.1.0" -o cmd/core-metadata/core-metadata ./cmd/core-metadata
| CGO_ENABLED=1 GO111MODULE=on go  build -ldflags "-X github.com/edgexfoundry/edgex-go.Version=1.1.0" -o cmd/core-data/core-data ./cmd/core-data
| CGO_ENABLED=0 GO111MODULE=on go  build -ldflags "-X github.com/edgexfoundry/edgex-go.Version=1.1.0" -o cmd/core-command/core-command ./cmd/core-command
| CGO_ENABLED=0 GO111MODULE=on go  build -ldflags "-X github.com/edgexfoundry/edgex-go.Version=1.1.0" -o cmd/support-logging/support-logging ./cmd/support-logging
| CGO_ENABLED=0 GO111MODULE=on go  build -ldflags "-X github.com/edgexfoundry/edgex-go.Version=1.1.0" -o cmd/support-notifications/support-notifications ./cmd/support-notifications
| go: bitbucket.org/bertimus9/systemstat@v0.0.0-20180207000608-0eeff89b0690: missing go.sum entry; to add it:
| 	go mod download bitbucket.org/bertimus9/systemstat
| CGO_ENABLED=0 GO111MODULE=on go  build -ldflags "-X github.com/edgexfoundry/edgex-go.Version=1.1.0" -o cmd/sys-mgmt-executor/sys-mgmt-executor ./cmd/sys-mgmt-executor
| make: *** [Makefile:32: cmd/config-seed/config-seed] Error 1
| make: *** Waiting for unfinished jobs....
| make: *** [Makefile:44: cmd/export-client/export-client] Error 1
| make: *** [Makefile:47: cmd/export-distro/export-distro] Error 1
| make: *** [Makefile:35: cmd/core-metadata/core-metadata] Error 1
| make: *** [Makefile:38: cmd/core-data/core-data] Error 1
| make: *** [Makefile:41: cmd/core-command/core-command] Error 1
| make: *** [Makefile:50: cmd/support-logging/support-logging] Error 1
| make: *** [Makefile:53: cmd/support-notifications/support-notifications] Error 1
| make: *** [Makefile:56: cmd/sys-mgmt-executor/sys-mgmt-executor] Error 1
| ERROR: oe_runmake failed
| WARNING: exit code 1 from a shell command.
Thanks in Advance!
930件の閲覧回数
Bio_TICFSL
