I compiled fsl-image-core with valgrind using hob in SDK1.6 ENV ,and start linux system with fsl-image-core-edited.rootfs.ext2.gz.u-boot.When I executing "valgrind ls -l",it prints "valgrind:unrecognised instruction...".How can i make valgrind work succcessfuly. I tried valgrind 3.10.0,but not work.
==2997==valgrind: unrecognised instrucion at address 0x401bac0
==2997== at 0x401bac0:memcpy (in /lib/ld-2.15.so)
==2997== at 0x4002b07:_dl_start_final (rtld.c:298)
==2997== at 0x40181ef:_start(in /lib/ld-2.15.so)
==2997== Your program just tried to execute an instruction that valgrind did not recognise.
CPU: B4860qds
Valgrind version: Valgrind-3.9.0 /3.10.0
Thank you in advance,
-Edward
