p2020rdb custom board ethernet issue
1,013 次查看
chandrashekarpa
facing issue with ethernet in custom board developed with p2020rdb ,
 In this board we populate section wise .we have two ethernets 'etsec3' & 'etsec1' ,first we populate etsec3 communication established ,
after that i tried to populate the 'etsec1' then it  is succesfully communication established, and etsec3 not working .
whats the problem??
Thank you in advance!!!!!!
标记 (1)
2 回复数
936 次查看
vinothkumars
Senior Contributor IV
Please check, both ports are use the same phy or different phy.
VinothS
Vinothkumar Sekar
936 次查看
chandrashekarpa
Using different phy
