iptables: No chain/target/match by that name. ls1021a
jiye
Contributor V
Kernel Debian 4.19
When I perform
 iptables -A syn_flood
and
iptables -A port-scanning
It throws me error says:
i am not sure if this is kernel related. If so what is the name of the module should I use?
alexander_yakov
"-A" appends a rule to the specified chain. In your case chain names are specified "syn_flood" and "port-scanning". Error "No chain/target/match by that name" means there are no such chains, and they should be explicitly created before adding a rule to each of them. A new chain is created by "iptables -N chan_name".
This question is more related to iptables and its syntax, than to kernel.
