how to debug boot loaded rcw by usb tap
9,988 次查看
jiachaozhang
Hi NXP:
        I  use jtag usb tap to debug T2080 rdb boot,   I load rcw by usb tap,
        but ,  the rcw  readed by boot is not equal to the rcw loaded by usb tap;
       please look up attachment for more detail;
        I want to know how to debug boot loaded rcw by usb tap;
       thinks a lot!
9,577 次查看
ufedor
Why in the "Attach" configuration you have enabled initialization script???
Please note that "Attach" should establish connection with already initialized processor - in your case it should be done by U-Boot.
9 回复数
9,577 次查看
jiachaozhang
thinks ufedor;
I can attach T2080 by usb tap to debug uboot step by step
9,577 次查看
jiachaozhang
in attachment ,  "boot-log.txt "  is uboot log
9,577 次查看
jiachaozhang
thinks a lot!
9,578 次查看
ufedor
9,577 次查看
jiachaozhang
thinks a lot!
now I want to debug uboot  by usb tap,    using rcw in flash.
 while I direct start  uboot , the uboot log print rcw is right, and uboot start  ok;
but while i use usb tap to debug uboot,  using rcw in flash, the uboot can not start ; and uboot log print error(ddr error), please look up attachment
how do i debug uboot using usb tap ?
thinks a lot!
9,577 次查看
ufedor
What exactly you have done in this case?
There is no attachment.
9,577 次查看
ufedor
If you describe the RCW override, then the described behaviour is by design.
What exactly you want to debug?
9,577 次查看
jiachaozhang
HI ufedor:
          I want to debug boot with rcw loaded by usb tap;
          but I find the rcw loaded by usb tap can not    become effective;
          could  you tell me how to load rcw by usb tap to debug boot ?
           thinks a lot!
9,575 次查看
ufedor
Please refer to the attached screenshot for the RCW override configuring.
