Get:515 http://archive.ubuntu.com/ubuntu focal/main amd64 ssh-import-id all 5.10-0ubuntu1 [10.0 kB]
Fetched 184 MB in 50s (3661 kB/s)
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libsystemd0_245.4-4ubuntu3.14_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl1.1_1.1.1f-1ubuntu2.10_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/p/python3.8/libpython3.8-minimal_3.8.10-0ubuntu1~20.04.2... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/p/python3.8/python3.8-minimal_3.8.10-0ubuntu1~20.04.2_am... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/p/python3.8/libpython3.8-stdlib_3.8.10-0ubuntu1~20.04.2_... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/p/python3.8/python3.8_3.8.10-0ubuntu1~20.04.2_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/c/cryptsetup/libcryptsetup12_2.2.2-3ubuntu2.3_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-timesyncd_245.4-4ubuntu3.14_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd_245.4-4ubuntu3.14_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/systemd-sysv_245.4-4ubuntu3.14_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/r/rsync/rsync_3.1.3-8ubuntu0.1_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/openssl_1.1.1f-1ubuntu2.10_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/t/tzdata/tzdata_2021e-0ubuntu0.20.04_all.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libnss-systemd_245.4-4ubuntu3.14_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/s/systemd/libpam-systemd_245.4-4ubuntu3.14_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/libx/libxml2/libxml2_2.9.10+dfsg-5ubuntu0.20.04.1_amd64.... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/v/vim/xxd_8.1.2269-1ubuntu5.4_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/v/vim/vim-common_8.1.2269-1ubuntu5.4_all.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm-common_2.4.105-3~20.04.2_all.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/libd/libdrm/libdrm2_2.4.105-3~20.04.2_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/openssh-client_8.2p1-4ubuntu0.3_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/a/alsa-ucm-conf/alsa-ucm-conf_1.2.2-1ubuntu0.11_all.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/glibc/libc-dev-bin_2.31-0ubuntu9.2_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/l/linux/linux-libc-dev_5.4.0-92.103_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/glibc/libc6-dev_2.31-0ubuntu9.2_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9/gcc-9-base_9.3.0-17ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9/cpp-9_9.3.0-17ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9/libasan5_9.3.0-17ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9/libgcc-9-dev_9.3.0-17ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9/gcc-9_9.3.0-17ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9/libstdc++-9-dev_9.3.0-17ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9/g++-9_9.3.0-17ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/gcc-9-aarch64-linux-gnu-base_9.3.0-17ubunt... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/cpp-9-aarch64-linux-gnu_9.3.0-17ubuntu1~20... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/gcc-9-arm-linux-gnueabihf-base_9.3.0-17ubu... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/cpp-9-arm-linux-gnueabihf_9.3.0-17ubuntu1~... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/gcc-9-cross-base_9.3.0-17ubuntu1~20.04cros... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/libasan5-arm64-cross_9.3.0-17ubuntu1~20.04... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/libgcc-9-dev-arm64-cross_9.3.0-17ubuntu1~2... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/gcc-9-aarch64-linux-gnu_9.3.0-17ubuntu1~20... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/libstdc++-9-dev-arm64-cross_9.3.0-17ubuntu... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/g++-9-aarch64-linux-gnu_9.3.0-17ubuntu1~20... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/libasan5-armhf-cross_9.3.0-17ubuntu1~20.04... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/libgcc-9-dev-armhf-cross_9.3.0-17ubuntu1~2... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/gcc-9-arm-linux-gnueabihf_9.3.0-17ubuntu1~... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/libstdc++-9-dev-armhf-cross_9.3.0-17ubuntu... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9-cross/g++-9-arm-linux-gnueabihf_9.3.0-17ubuntu1~... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/p/python3.8/libpython3.8_3.8.10-0ubuntu1~20.04.2_amd64.d... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/gdb/gdb_9.2-0ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/gdb/gdbserver_9.2-0ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9/libgfortran-9-dev_9.3.0-17ubuntu1~20.04_amd64.de... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/g/gcc-9/gfortran-9_9.3.0-17ubuntu1~20.04_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/n/nvidia-settings/libxnvctrl0_470.57.01-0ubuntu0.20.04.2_... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/z/zlib/zlib1g-dev_1.2.11.dfsg-2ubuntu1.2_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/m/mesa/libgbm1_21.0.3-0ubuntu0.3~20.04.5_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/p/python3.8/libpython3.8-dev_3.8.10-0ubuntu1~20.04.2_amd... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/r/ruby2.7/ruby2.7_2.7.0-5ubuntu1.5_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/r/ruby2.7/libruby2.7_2.7.0-5ubuntu1.5_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssl/libssl-dev_1.1.1f-1ubuntu2.10_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/libx/libxml2/libxml2-dev_2.9.10+dfsg-5ubuntu0.20.04.1_am... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/openssh-sftp-server_8.2p1-4ubuntu0.3_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/o/openssh/openssh-server_8.2p1-4ubuntu0.3_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/p/python3.8/python3.8-dev_3.8.10-0ubuntu1~20.04.2_amd64.... 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/q/qemu/qemu-block-extra_4.2-3ubuntu6.19_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/q/qemu/qemu-system-common_4.2-3ubuntu6.19_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/universe/q/qemu/qemu-user-static_4.2-3ubuntu6.19_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/q/qemu/qemu-utils_4.2-3ubuntu6.19_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/v/vim/vim-runtime_8.1.2269-1ubuntu5.4_all.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://security.ubuntu.com/ubuntu/pool/main/v/vim/vim_8.1.2269-1ubuntu5.4_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Failed to fetch http://archive.ubuntu.com/ubuntu/pool/main/g/glibc/libc6-dbg_2.31-0ubuntu9.2_amd64.deb 404 Not Found [IP: 91.189.91.39 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
The command '/bin/sh -c apt-get install -y u-boot-tools device-tree-compiler autoconf automake dh-autoreconf libssl-dev zip openssl curl flex bison bc git gcc vim ethtool wget ftp make makedev tclsh ccache binfmt-support qemu-system-common qemu-user-static debootstrap sudo ncurses-dev gcc-arm-linux-gnueabihf crossbuild-essential-arm64 gcc-aarch64-linux-gnu file build-essential gdb u-boot-tools device-tree-compiler python3 python3-dev python3-pip libxml2-dev libsensors4-dev libssl-dev libedit-dev liblzma-dev tree binutils-dev libnuma-dev libpcap-dev libtool mtd-utils libncurses5-dev libelf-dev net-tools libcunit1-dev pkg-config autotools-dev crossbuild-essential-armhf openssh-server openssh-client crossbuild-essential-armhf qemu-utils kmod g++-aarch64-linux-gnu cpp-arm-linux-gnueabihf dosfstools ruby iputils-ping cpio rsync libtclap-dev parted rpm2cpio lsb-release xutils-dev libwayland-bin cmake locales texinfo gawk chrpath diffstat scons libgflags-dev libhdf5-serial-dev python3-numpy python3-wheel python3-h5py python3-pyelftools meson pandoc' returned a non-zero code: 100
make: *** [build] Error 100
There is networking configuration problem on your build host.
If your Linux host machine is in a subnet that needs HTTP(s) proxy to access external Internet, please set environment variable
http_proxy and https_proxy as below:
1. Set proxy in ~/.bashrc (for current user) or in /etc/profile.d/proxy.sh (for global users), then run "source ~/.bashrc" or
"source /etc/profile.d/proxy.sh" to validate the settings.
export http_proxy="http://<account>:<password>@<domain>:<port>"
export https_proxy="https://<account>:<password>@<domain>:<port>"
2. Set proxy in /etc/apt/apt.conf
Acquire::http::Proxy "http://<account>:<password>@<domain>:<port>";
Acquire::https::Proxy "https://<account>:<password>@<domain>:<port>";
Thanks !
