after SDK installtion,at the installation path,it created the folder QorIQ-SDK-V2.0-20160527-yocto with
sstate-cache subfolder. host-prepare.sh file not found in the installation folder
Use the following command sequence for SDK installing under Ubuntu 14.04:
Message: /bin/sh -> dash
b) command: sudo dpkg-reconfigure dash
Answer after password – No
Message:
Removing 'diversion of /bin/sh to /bin/sh.distrib by dash'
Adding 'diversion of /bin/sh to /bin/sh.distrib by bash'
Removing 'diversion of /usr/share/man/man1/sh.1.gz to /usr/share/man/man1/sh.distrib.1.gz by dash'
Adding 'diversion of /usr/share/man/man1/sh.1.gz to /usr/share/man/man1/sh.distrib.1.gz by bash'
c) command for checking: ls -l /bin/sh
Message: /bin/sh -> bash
Usually Linux recommends also run the following command: sudo usr/sbin/visudo
Pavel Chubakov
Hi Pavel
can you please tell me "how to install SDK for a core" and and how to install SDK source
thanks
Niranjan
