Where is a package thermal characteristics for LS1046A?
jwlee
Hi All
I want a package thermal characteristics for LS1046A
Psi JT
Unfortunately, I didn't design a temperature sensor using the thermal diode of the LS1046A.
I need to estimate real junction temperature of LS1046A using a Psi JT.
ufedor
Please note that Psi JT is not applicable for LS1046A which must be used with a heat sink.
For details you can refer to the following document:
https://www.renesas.com/in/en/www/doc/whitepapers/thermal-characterization-of-packaged-semiconductor...
Available thermal characteristics are provided in the QorIQ LS1046A, LS1026A Data Sheet, Table 142. Package thermal characteristics.
