U-boot generated with sdk1.7 failed on t1040rdb
1,244 次查看
pmidol
Hello
I generate an image and u-boot for  t1040rdb with sdk1.7. I try to run this image on a simulated t1040rdb board with simics.
Uboot start and  is stuck trying to access somewhere in memory where nothing is mapped (0xff5000e08).
The image work fine using the old u-boot generated with sdk 1.6.
What are the difference between the two u-boot version generated by sdk 1.6 and 1.7?
Philippe
0 回复数
