TWR-LS1021A
TWR-LS1021A
christopherbisc
I ordered a TWR-LS1021A development board and was notified by the distributor (digikey) that the producer is not able to deliver this board.
Can someone tell me when, or if the board will be available again?
What is the reason for the unavailability of the TWR-LS1021A?
Tags (2)
alexander_yakov
Yes, we typically offer only one revision of board at a time. For this moment I see two partnumbers listed at board product page, "Buy/Parametrics" tab, this means we are now in process of transition to a new partnumber. At this moment orders for old partnumber may be declined (depending on stock quantities), while new partnumber lead time may be little bit longer than expected due to big number of first orders. Please double-check with your distributor for exact lead time.
Alexander
TIC
christopherbisc
I ordered the revision TWR-LS1021A-PC with the Digikey part number 568-13372-ND about a month ago and got notified that the supplier cannot give a date of delivery. So it is already the new revision.
I will check the lead time with Digikey again.
Thank you for the replies.
alexander_yakov
Alexander
TIC
sinanakman
Senior Contributor III
Hi Christopher
Which revision did you order ? I believe TWR-LS1021A-PB is not manufactured
any more. There is TWR-LS1021A-PC now with part number 568-13372-ND from
Digikey. It is not in stock but looks like it is available and shows the standard lead time.
I wonder if you ordered the revision that is not available anymore.
Hope this helps
Sinan Akman
