TWR-LS1021A: No sound card available in SD_BOOT mode with Kernel Panic in idle mode
skrishnakar
Hello All,
I am booting SDK-v1.7 on TWR-LS1021A (x3) board in SD_BOOT mode. Unfortunately I am seeing that "vf610-sgtl5000" sound card is failing to register. This is default kernel and u-boot from sdk-v1.7 (rebuilt with SD_BOOT support).
Logs:
U-Boot SPL 2014.07-sdk-v1.7.x+g659b6a2 (Feb 05 2015 - 20:55:16)
U-Boot 2014.07-sdk-v1.7.x+g659b6a2 (Feb 05 2015 - 20:55:16)
CPU:   Freescale LayerScape LS1021E, Version: 1.0, (0x87081110)
Clock Configuration:
       CPU0(ARMV7):1000 MHz,
       Bus:300  MHz, DDR:800  MHz (1600 MT/s data rate),
Reset Configuration Word (RCW):
       00000000: 0608000a 00000000 00000000 00000000
       00000010: 20000000 00407900 60040a00 21046000
       00000020: 00000000 00000000 00000000 00038000
       00000030: 00080000 881b7340 00000000 00000000
Board: LS1021ATWR
CPLD:  V2.3
PCBA:  V4.0
VBank: 1
I2C:   ready
DRAM:  1 GiB
Using SERDES1 Protocol: 32 (0x20)
Flash: 128 MiB
MMC:   FSL_SDHC: 0
In:    serial
Starting kernel ...
Booting Linux on physical CPU 0xf00
Initializing cgroup subsys cpuset
Initializing cgroup subsys cpuacct
Linux version 3.12.19-rt30+ (root@lenovo) (gcc version 4.9.1 (Sourcery CodeBench 2014.11-36) ) #2 SMP Thu Feb 5 21:51:04 IST 2015
CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=70c73c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine: Freescale LS1021A, model: LS1021A TWR Board
Memory policy: ECC disabled, Data cache writealloc
PERCPU: Embedded 7 pages/cpu @80d72000 s8192 r8192 d12288 u32768
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260096
hw-breakpoint: maximum watchpoint size is 8 bytes.
bio: create slab <bio-0> at 0
3P3V: 3300 mV
vgaarb: loaded
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
i2c i2c-2: of_i2c: modalias failure on /soc/i2c@21a0000/ltc2945@67
i2c i2c-2: IMX I2C adapter registered
hub 2-1:1.0: 4 ports detected
sgtl5000: probe of 1-000a failed with error -110
vf610-sgtl5000 sound.9: ASoC: CODEC (null) not registered
vf610-sgtl5000 sound.9: TWR-AUDIO-SGTL board required :-517
platform sound.9: Driver vf610-sgtl5000 requests probe deferral
oprofile: using timer interrupt.
TCP: cubic registered
Initializing XFRM netlink socket
NET: Registered protocol family 15
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
Key type dns_resolver registered
regulator-dummy: disabling
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
libphy: mdio@2d24000:02 - Link is Down
root@ls1021atwr:~# cat /proc/asound/cards
--- no soundcards ---
Followed with kernel panic, in idle mode:
root@ls1021atwr:~# INFO: rcu_sched self-detected stall on CPU { 0}  (t=2100 jiffies g=107 c=106 q=7)
CPU: 0 PID: 0 Comm: swapper/0 Not tainted 3.12.19-rt30+ #2
[<80010899>] (unwind_backtrace+0x1/0x8c) from [<8000e3ff>] (show_stack+0xb/0xc)
[<8000e3ff>] (show_stack+0xb/0xc) from [<803146cf>] (dump_stack+0x4b/0x60)
[<803146cf>] (dump_stack+0x4b/0x60) from [<8005686f>] (rcu_check_callbacks+0x121/0x3f2)
[<8005686f>] (rcu_check_callbacks+0x121/0x3f2) from [<8001fc53>] (update_process_times+0x2b/0x44)
[<8001fc53>] (update_process_times+0x2b/0x44) from [<80044b7b>] (tick_periodic+0x6b/0x88)
[<80044b7b>] (tick_periodic+0x6b/0x88) from [<80044c99>] (tick_handle_periodic+0x19/0x64)
[<80044c99>] (tick_handle_periodic+0x19/0x64) from [<8026928f>] (arch_timer_handler_phys+0x1f/0x26)
[<8026928f>] (arch_timer_handler_phys+0x1f/0x26) from [<8003dc6f>] (handle_percpu_devid_irq+0x3f/0x54)
[<8003dc6f>] (handle_percpu_devid_irq+0x3f/0x54) from [<8003b9c3>] (generic_handle_irq+0x13/0x1c)
[<8003b9c3>] (generic_handle_irq+0x13/0x1c) from [<8000c8fd>] (handle_IRQ+0x3d/0x60)
[<8000c8fd>] (handle_IRQ+0x3d/0x60) from [<800083d3>] (gic_handle_irq+0x2b/0x44)
[<800083d3>] (gic_handle_irq+0x2b/0x44) from [<8031745b>] (__irq_svc+0x3b/0x5c)
Exception stack(0x804edeb0 to 0x804edef8)
dea0:                                     00000001 00200000 00000100 00000000
dec0: 804ec018 00000000 00000082 8052ee00 80003010 410fc075 0000000a 00000000
dee0: 00000000 804edef8 8001b4c7 8001b506 400e0133 ffffffff
[<8031745b>] (__irq_svc+0x3b/0x5c) from [<8001b506>] (__do_softirq+0x52/0x120)
[<8001b506>] (__do_softirq+0x52/0x120) from [<8001b639>] (do_softirq+0x2d/0x38)
[<8001b639>] (do_softirq+0x2d/0x38) from [<8001bb65>] (irq_exit+0x4f/0x8e)
[<8001bb65>] (irq_exit+0x4f/0x8e) from [<8000c901>] (handle_IRQ+0x41/0x60)
[<8000c901>] (handle_IRQ+0x41/0x60) from [<800083d3>] (gic_handle_irq+0x2b/0x44)
Exception stack(0x804edf70 to 0x804edfb8)
df60:                                     ffffffed 00000000 00889000 00000000
df80: 804ec000 804ec000 804ddf00 80d6fd40 80003010 410fc075 00000000 00000000
dfa0: 00000008 804edfb8 8000cae5 8000cae6 600e0033 ffffffff
[<8031745b>] (__irq_svc+0x3b/0x5c) from [<8000cae6>] (arch_cpu_idle+0x1a/0x20)
[<8000cae6>] (arch_cpu_idle+0x1a/0x20) from [<8003b95d>] (cpu_startup_entry+0x7d/0xc4)
[<8003b95d>] (cpu_startup_entry+0x7d/0xc4) from [<804be819>] (start_kernel+0x221/0x274)
nfs: server 134.86.60.179 not responding, still trying
INFO: rcu_sched self-detected stall on CPU { 0}  (t=8403 jiffies g=107 c=106 q=7)
INFO: rcu_sched self-detected stall on CPU { 0}  (t=14706 jiffies g=107 c=106 q=7)
Any inputs on sound card issue and kernel panic in idle mode are really appreciated.
Srikanth
