SDK Error while bitbake fsl-image-minimal on centos 5.9
Search instead for
phenixyan
[yw079@localhost build_t2080rdb-64b]$ bitbake fsl-image-minimal
Traceback (most recent call last):
File "/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/bin/bitbake", line 31, in <module>
import bb
File "/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/__init__.py", line 77, in <module>
from bb import fetch2 as fetch
File "/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/fetch2/__init__.py", line 37, in <module>
import bb.persist_data, bb.utils
File "/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/persist_data.py", line 35, in <module>
from pysqlite2 import dbapi2 as sqlite3
ImportError: No module named pysqlite2
/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/event.py:118: RuntimeWarning: Parent module 'bb' not found while handling absolute import
from bb.msg import BBLogFormatter
Error in atexit._run_exitfuncs:
File "/usr/local/lib/python2.7/atexit.py", line 24, in _run_exitfuncs
func(*targs, **kargs)
File "/opt/phenix/nxp/QorIQ-SDK-V2.0-20160527-yocto/sources/poky/bitbake/lib/bb/event.py", line 118, in print_ui_queue
Error in sys.exitfunc:
srak
How to fix? I'm facing same issue. Ubuntu 20.04 on WSL.
yipingwang
Hello Phenix Yan,
Please execute the script sources/meta-freescale/scripts/host-prepare.sh to setup the necessary host environment for building.
The python version should be greater than 2.7.3, after execute the script, please export python path as the following.
export PATH=/opt/python-2.7.3/bin/:$PATH
In addition, please sqlite3 and sqlite3-devel on your machine.
Yiping
srak
facing same issue! I'm using ubuntu 18.06.4, trying to build for ls1046ardb
B-Nagendra
hello NXP
I am facing similar issue on ubuntu
installed python  2.7.6.  sqlite3 and libsqlite3-dev
trying to compile fsl-image-minimal for t1042d4rdb
log:
getting below error with python3.4
Bitbake is not compatible with python v3
Please set up python v2 as your default python interpreter
what is the solution for this ?
mertsalar137
Did you find a solution? I am facing same issue.
