QorIQ T1024 Power Sequence
Angel_OLG
A customer is using the QorIQ T1024 and they have trouble understanding the power sequence of the MPU. First, let me understand if a PMIC from NXP is necessary for these devices? if that is the case, Which PMIC is recommended for use with the T1024?
The power Supply figure (Figure 2-1) on Reference Design Board connects the supply pins through different Buck ICs suppliers.
Regards, and thanks in advance.
