I'm trying to find out the best kernel supported by Xenomai and I'm testing different versions of the kernel on my custom board using P1020 CPU. Every time I use the same DTB (fragment below)
sdhc@2e000 {
compatible = "fsl,p1020-esdhc", "fsl,esdhc";
reg = <0x2e000 0x1000>;
interrupts = <0x48 0x2 0x0 0x0>;
clock-frequency = <0x0>;
sdhci,auto-cmd12;
non-removable;
and the same defconfig (mpc_85xx_smp_defconfig).
Currently I run system from TFTP, but noticed different different eMMC (would like to put kernel and rootfs finally there) behavior on different kernels.
My eMMC is Greenliant GLS85VM1001P-S-I-LFWE-ND201 (MMC v4.4), connected using 4-bit interface to P1020. It is powered by 3.3V power supply.
That eMMC works fine only on:
- kernel provided by NXP SDK 1.9 (it's 3.12.37-rt51+g43cecda).
- latest vanilla 4.5.2
It works partially on vanilla 3.14.
I'm wondering what is the reason? Do I need special entries in DTB for eMMC or P1020 esdhc controller for some kernels? Is P1020 or eMMC support for that particular chip broken in some kernels (3.18, 4.1?)?
May some troubles be caused that my eMMC card is v4.4 but P1020 supports only v4.2?
I'm a kernel newbe, but maybe backporting of 4.5.2 drivers to 4.1.x should solve the problem? Which files should be backported?
I understand that community takes care mainly about SDK and NXP kernels, but maybe someone has some other experience and could give some hint.
More details:
On SDK kernel 3.12 and vanilla 4.5.2 everything works fine (card is detected, can be mounted and read/written).
On following versions I've tested, there are problems:
- vanilla 3.14
- vanilla 3.18
- vanilla 4.1 (I'd prefer to use that one because it is the most recent kernel with Xenomai patch available)
- vanilla 4.4
SDK 3.12 - OK
root@p1020rdb:~# uname -a
Linux p1020rdb 3.12.37-rt51+g43cecda #1 SMP PREEMPT RT Tue Apr 26 08:08:29 CEST 2016 ppc GNU/Linux
root@p1020rdb:~# cat /sys/kernel/debug/mmc0/ios
clock: 52000000 Hz
vdd: 7 (1.65 - 1.95 V) Why is there wrong voltage?
bus mode: 2 (push-pull)
chip select: 0 (don't care)
power mode: 2 (on)
bus width: 2 (4 bits)
timing spec: 1 (mmc high-speed)
signal voltage: 0 (3.30 V)
root@p1020rdb:~# ls /dev/mmcblk0*
/dev/mmcblk0 /dev/mmcblk0boot0 /dev/mmcblk0boot1 /dev/mmcblk0p1 /dev/mmcblk0p2
Vanilla 3.14.67 - PARTIALLY OK
Some errors during startup, wrong bus width detected, but card can be mounted and accessed:
Linux p1020rdb 3.14.67 #3 SMP PREEMPT Wed Apr 27 09:45:24 CEST 2016 ppc GNU/Linux
clock: 52000000 Hz
vdd: 21 (3.3 ~ 3.4 V)
power mode: 2 (on)
bus width: 0 (1 bits) wrong bus width detected?
mmc0: new high speed MMC card at address 0001
mmcblk0: mmc0:0001 VM010B 868 MiB
mmcblk0boot0: mmc0:0001 VM010B partition 1 512 KiB
mmcblk0boot1: mmc0:0001 VM010B partition 2 512 KiB
mmc0: Got data interrupt 0x00600000 even though no data operation was in progress.
mmc0: Got data interrupt 0x00200000 even though no data operation was in progress.
mmc0: Got data interrupt 0x0060000a even though no data operation was in progress.
mmcblk0: error -84 transferring data, sector 0, nr 8, cmd response 0x900, card status 0x0
mmcblk0: retrying using single block read
mmcblk0: p1 p2
mmcblk0boot1: unknown partition table
mmcblk0boot0: unknown partition table
Vanilla 3.18.31 - NOT OK
System continously prints following message every few seconds:
mmc0: Timeout waiting for hardware interrupt.
Linux p1020rdb 3.18.31 #1 SMP Fri Apr 22 17:54:30 CEST 2016 ppc GNU/Linux
clock: 400000 Hz
power mode: 2 (on)
timing spec: 0 (legacy)
root@p1020rdb:~# dmesg | grep mmc
sdhci-esdhc e3e2e000.sdhc: No vmmc regulator found
sdhci-esdhc e3e2e000.sdhc: No vqmmc regulator found
mmc0: SDHCI controller on e3e2e000.sdhc [e3e2e000.sdhc] using DMA
root@p1020rdb:~# ls /dev/mmc*
ls: /dev/mmc*: No such file or directory
Vanilla 4.1.22 - NOT OK
There are errors during startup, card cannot be mounted.
Linux p1020rdb 4.1.22 #2 SMP Mon Apr 25 23:34:01 CEST 2016 ppc GNU/Linux
clock: 52000000 Hz
power mode: 2 (on)
mmc0: mmc_rescan_try_freq: trying to init card at 400000 Hz
mmc0: switch to bus width 1 failed
mmc0: tried to reset card
blk_update_request: I/O error, dev mmcblk0, sector 0
mmcblk0: error -84 transferring data, sector 1, nr 7, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 1
Vanilla 4.5.2 - OK
Linux p1020rdb 4.5.2 #1 SMP Tue Apr 26 12:29:53 CEST 2016 ppc GNU/Linux
clock: 52000000 Hz
actual clock: 49999999 Hz
power mode: 2 (on)
driver type: 0 (driver type B)
I have also tried https://github.com/Freescale/linux-fslc . Unfortunately it also does not work with my eMMC:
mmcblk0: error -84 transferring data, sector 2, nr 6, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 2
mmcblk0: error -84 transferring data, sector 3, nr 5, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 3
mmcblk0: error -84 transferring data, sector 4, nr 4, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 4
mmcblk0: error -84 transferring data, sector 5, nr 3, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 5
mmcblk0: error -84 transferring data, sector 6, nr 2, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 6
mmcblk0: error -84 transferring data, sector 7, nr 1, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 7
Buffer I/O error on dev mmcblk0, logical block 0, async page read
clock: 52000000 Hz
power mode: 2 (on)
root@p1020rdb:~# mmc extcsd read /dev/mmcblk0
sdhci-esdhc e3e2e000.sdhc: mmc_blk_ioctl_cmd: data error -84
ioctl: Invalid or incomplete multibyte or wide cmmcblk0: error -84 transferring data, sector 1777536, nr 8, cmd response 0x900, card status 0x0
haracter
Could mmcblk0: retrying using single block read
not read EXT_CSDmmcblk0: error -84 transferring data, sector 1777536, nr 8, cmd response 0x900, card status 0x0
from /dev/mmcblblk_update_request: 158 callbacks suppressed
k0
root@p1020rdblk_update_request: I/O error, dev mmcblk0, sector 1777536
b:~# mmcblk0: error -84 transferring data, sector 1777537, nr 7, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 1777537
mmcblk0: error -84 transferring data, sector 1777538, nr 6, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 1777538
mmcblk0: error -84 transferring data, sector 1777539, nr 5, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 1777539
mmcblk0: error -84 transferring data, sector 1777540, nr 4, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 1777540
mmcblk0: error -84 transferring data, sector 1777541, nr 3, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 1777541
mmcblk0: error -84 transferring data, sector 1777542, nr 2, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 1777542
mmcblk0: error -84 transferring data, sector 1777543, nr 1, cmd response 0x900, card status 0x0
blk_update_request: I/O error, dev mmcblk0, sector 1777543
buffer_io_error: 8 callbacks suppressed
Buffer I/O error on dev mmcblk0, logical block 222192, async page read
root@p1020rdb:~#
