P1010: How to do pin muxing for P1010RDB in linux kernel
1,586 次查看
nobelsharanyanj
How to do pin muxing for the board p1010? what are the files I need to check?
1,243 次查看
ufedor
The "p1010rdb.c" is U-Boot component.
8 回复数
1,243 次查看
ufedor
> Is there any standard way to define in device tree regarding pin muxing?
No. This has to be done in U-Boot.
1,243 次查看
scottwood
Actually, there is.  See Documentation/devicetree/bindings/pinctrl/pinctrl-bindings.txt
Currently we usually handle this in U-Boot, but putting it in the device tree would be better, as it could allow Linux to dynamically reconfigure.
1,243 次查看
ufedor
Please explain which exactly "pin muxing" and "board p1010" are in question.
1,243 次查看
nobelsharanyanj
Hi ufedor,
I am using P1010 rev 2, custom board.
I wish to use GPIO[6:9] instead of SPI,
GUTS_PMUXCR1 by default expose to SPI signal.
I like to know what is the suitable way of modifying the register to support my need.
1,243 次查看
ufedor
It is needed to set GUTS_PMUXCR1[SPI]=0b10 in the p1010rdb.c
1,243 次查看
nobelsharanyanj
ok,
Where does "GUTS_PMUXCR1" defined in kernel.
1,244 次查看
ufedor
1,243 次查看
nobelsharanyanj
ok, I will look into uboot too,
In kernel,
compatible = "fsl,p1010-guts"; is been defined in "arch/powerpc/boot/dts/fsl/p1010si-post.dtsi".
That mean we can use device tree to get io_mem of that structure and we can re modify it in arch/powerpc/platforms/85xx/p1010rdb.c
Is there any standard way to define in device tree regarding pin muxing? so that I have kernel image common, for which I can support two or more board with device tree alone.
