May P2020 be broken if I applied power without any pll configuration resistors?
1,001 次查看
igorvereshchagi
Hello community,
Thank you
1 回复
935 次查看
LPP
PLL configuration pins do not have default values. If they are not strapped during reset then random settings are applied.
We do not expect device damage but likely the device will not boot properly.
Pavel
