Hi All,
I am working on T4240RDB-64B machine. I want to program DDR alone using lauterbach and also I am new to lauterbach. So, I don't know which command want to use for Initialize the SDRAM.
I want to you guys support for use lauterbach specific commands for flash SDRAM.
Thank you for all your support......!
Regards, VinothS
Solved! Go to Solution.
Hi VinothS,
you can find example setup scripts for QorIQ T4 processors and boards in your TRACE32 installation directory under demo\powerpc64bit\hardware\qoriq_t4\
If you don't have the demo folder in your installation, you can also download the scripts from here: TRACE32® Start-Up and other Scripts (search for T4240)
Reinhard
Hi VinothS,
Reinhard
Please ask the Lauterbach technical support directly because NXP directly supports only CodeWarrior and do not have resources to support third-party tools.
Hi Ufedor,
Thank you for your quick response.
Regards, VinothS
