Lauterbach Debugger support to T4240RDB-64B
1,288件の閲覧回数
vinothkumars
Senior Contributor IV
Hi All,
I am working on T4240RDB-64B machine. I want to program DDR alone using lauterbach and also I am new to lauterbach. So, I don't know which command want to use for Initialize the SDRAM.
I want to you guys support for use lauterbach specific commands for flash SDRAM.
Thank you for all your support......!
Regards, VinothS
Vinothkumar Sekar
956件の閲覧回数
rweiss
Contributor V
Hi VinothS,
you can find example setup scripts for QorIQ T4 processors and boards in your TRACE32 installation directory under demo\powerpc64bit\hardware\qoriq_t4\
If you don't have the demo folder in your installation, you can also download the scripts from here: TRACE32® Start-Up and other Scripts (search for T4240)
Reinhard
3 返答(返信)
957件の閲覧回数
rweiss
Contributor V
Hi VinothS,
Reinhard
956件の閲覧回数
ufedor
Please ask the Lauterbach technical support directly because NXP directly supports only CodeWarrior and do not have resources to support third-party tools.
956件の閲覧回数
vinothkumars
Hi Ufedor,
Thank you for your quick response.
Regards, VinothS
Vinothkumar Sekar
