LX2160A XSPI output setup/hold time
1,939 次查看
tamilm
Hi Team, I am currently using LX2160A for my project. i am planning to use XSPI for configure the slave device. i am not found any setup/hold time for XSPI Output timing in datasheet. Minimum Setup time of my slave device is 5.5ns. please share me the setup/hold time for output on XSPI.
Tamil
标记 (3)
1 回复
1,840 次查看
ufedor
Please mark (draw) timing(s) which are required and not present in the attached SDR timing diagram.
