When i build LS2088 with Ubuntu 18.09 on VM version 6.0
ake[4]: Leaving directory '/home/ranga/MTP/target/nxp-lsdk/flexbuild_lsdk1809/packages/apps/ovs-dpdk'
Makefile:5526: recipe for target 'install-recursive' failed
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory '/home/ranga/MTP/target/nxp-lsdk/flexbuild_lsdk1809/packages/apps/ovs-dpdk'
Makefile:5831: recipe for target 'install' failed
make[2]: *** [install] Error 2
make[2]: Leaving directory '/home/ranga/MTP/target/nxp-lsdk/flexbuild_lsdk1809/packages/apps/ovs-dpdk'
Makefile:151: recipe for target 'ovs-dpdk' failed
make[1]: *** [ovs-dpdk] Error 2
make[1]: Leaving directory '/home/ranga/MTP/target/nxp-lsdk/flexbuild_lsdk1809/packages/apps'
Makefile:24: recipe for target 'apps' failed
make: *** [apps] Error 2
make: Leaving directory '/home/ranga/MTP/target/nxp-lsdk/flexbuild_lsdk1809'
I am using the below build command.
flex-builder -i autobuild-log -a arm64 -m ls2088ardb
what could be the cause of APP errors.
regards,
ranga
Please run the following commands to generate boot partition, build apps and merge all components package to rootfs and compress distro rootfs as .tgz.
$ flex-builder -i mkrfs -a arm64
$ flex-builder -c apps -a arm64
$ flex-builder -i mkbootpartition -a arm64
$ flex-builder -i merge-component -a arm64
$ flex-builder -i compressrfs -a arm64
