LS1043A hangs at boot from removable storage device
conara
I am trying to boot a LSDK images as described in the Quick Start Guide, but it doesn't work as I expect:
1. Execute the following flex-installer command to automatically install LSDK default
xxx@ubuntu:~$ sudo flex-installer -i auto -m ls1043ardb -d /dev/sdd
[sudo] password for xxx:
/dev/sdd: 60 GB
Partitioning /dev/sdd ...
Formatting partitions ...
Model: Kingston DataTraveler 3.0 (scsi)
Disk /dev/sdd: 62.0GB
Sector size (logical/physical): 512B/512B
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 1      71.3MB  206MB   134MB   primary  ext4
 2      207MB   2354MB  2147MB  primary  ext4
 3      2355MB  7724MB  5369MB  primary  ext4
 4      7725MB  62.0GB  54.3GB  primary  ext4
partition and format /dev/sdd     [Done]
 Downloading http://www.nxp.com/lgfiles/sdk/lsdk2108/firmware_ls1043ardb_sdboot.img ...
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 51.9M  100 51.9M    0     0  14.1M      0  0:00:03  0:00:03 --:--:-- 14.1M
-rw-r--r-- 1 root root 54497255 Aug 27 16:20 firmware_ls1043ardb_sdboot.img
 Downloading http://www.nxp.com/lgfiles/sdk/lsdk2108/boot_LS_arm64_lts_5.10.tgz ...
100  351M  100  351M    0     0  19.0M      0  0:00:18  0:00:18 --:--:-- 18.9M
 Downloading http://www.nxp.com/lgfiles/sdk/lsdk2108/rootfs_lsdk2108_ubuntu_main_arm64.tgz ...
100  775M  100  775M    0     0  17.7M      0  0:00:43  0:00:43 --:--:-- 19.4M
Downloaded distro images [Done]
53219+1 records in
53219+1 records out
54497255 bytes (54 MB, 52 MiB) copied, 5.36574 s, 10.2 MB/s
Program firmware_ls1043ardb_sdboot.img into /dev/sdd with offset 4K     [Done]
Installing boot_LS_arm64_lts_5.10.tgz to /dev/sdd2 ...
Install boot_LS_arm64_lts_5.10.tgz in /dev/sdd2     [Done]
Installing rootfs_lsdk2108_ubuntu_main_arm64.tgz to /dev/sdd4 ...
Install rootfs_lsdk2108_ubuntu_main_arm64.tgz in /dev/sdd4     [Done]
setting PARTUUID for boot partition /dev/sdd2 ...
syncing data ...
Installation completed successfully
Installation seems good to me. After that I plugged it in the board:
U-Boot 2017.07-g503eff0 (Sep 26 2017 - 15:00:50 +0800)
SoC:  LS1043AE Rev1.1 (0x87920011)
Clock Configuration:
       CPU0(A53):1600 MHz  CPU1(A53):1600 MHz  CPU2(A53):1600 MHz
       CPU3(A53):1600 MHz
       Bus:      400  MHz  DDR:      1600 MT/s  FMAN:     500  MHz
Reset Configuration Word (RCW):
       00000000: 08100010 0a000000 00000000 00000000
       00000010: 14550002 80004012 e0025000 c1002000
       00000020: 00000000 00000000 00000000 00038800
       00000030: 00000000 00001101 00000096 00000001
Model: LS1043A RDB Board
Board: LS1043ARDB, boot from vBank 4
CPLD:  V2.0
PCBA:  V6.0
SERDES Reference Clocks:
SD1_CLK1 = 156.25MHZ, SD1_CLK2 = 100.00MHZ
I2C:   ready
DRAM:  Initializing DDR....
Detected UDIMM Fixed DDR on board
1.9 GiB (DDR4, 32-bit, CL=11, ECC off)
Using SERDES1 Protocol: 5205 (0x1455)
SEC0: RNG instantiated
PPA Firmware: Version LSDK-17.09
Firmware 'Microcode version 0.0.1 for LS1021a r1.0' for 1021 V1.0
QE: uploading microcode 'Microcode for LS1021a r1.0' version 0.0.1
Flash: 128 MiB
NAND:  512 MiB
MMC:   FSL_SDHC: 0
EEPROM: NXID v1
In:    serial
Out:   serial
Err:   serial
Net:   Fman1: Uploading microcode version 108.4.9
PCIe0: pcie@3400000 disabled
PCIe1: pcie@3500000 Root Complex: no link
PCIe2: pcie@3600000 Root Complex: no link
FM1@DTSEC1, FM1@DTSEC2, FM1@DTSEC3 [PRIME], FM1@DTSEC4, FM1@DTSEC5, FM1@DTSEC6, FM1@TGEC1
Hit any key to stop autoboot:  0
MMC: no card present
mmc_init: -123, time 1001
starting USB...
USB0:   Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   Register 200017f NbrPorts 2
USB XHCI 1.00
USB2:   Register 200017f NbrPorts 2
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 1 for devices... 2 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
USB device 0:
    Device 0: Vendor: Kingston Rev: 0000 Prod: DataTraveler 3.0
            Type: Removable Hard Disk
            Capacity: 59120.0 MB = 57.7 GB (121077761 x 512)
... is now current device
Scanning usb 0:1...
Scanning usb 0:2...
Found U-Boot script /ls1043ardb_boot.scr
965 bytes read in 728 ms (1000 Bytes/s)
## Executing script at 80000000
41159168 bytes read in 71644 ms (560.5 KiB/s)
39769 bytes read in 331 ms (117.2 KiB/s)
## Flattened Device Tree blob at 90000000
   Booting using the fdt blob at 0x90000000
   Using Device Tree in place at 0000000090000000, end 000000009001cb58
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 5.10.35 (jenkins@pluto) (aarch64-linux-gnu-gcc (Ubuntu 9.3.0-17ubuntu1~20.04) 9.3.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1 SMP PREEMPT Fri Aug 27 22:03:58 CST 2021
[    0.000000] Machine model: LS1043A RDB Board
[    0.000000] earlycon: uart8250 at MMIO 0x00000000021c0500 (options '')
[    0.000000] printk: bootconsole [uart8250] enabled
[    0.000000] efi: UEFI not found.
[    0.000000] OF: reserved mem: initialized node qman-fqd, compatible id fsl,qman-fqd
[    0.000000] OF: reserved mem: initialized node qman-pfdr, compatible id fsl,qman-pfdr
[    0.000000] OF: reserved mem: initialized node bman-fbpr, compatible id fsl,bman-fbpr
[    0.000000] cma: Reserved 32 MiB at 0x00000000f6000000
[    0.000000] NUMA: No NUMA configuration found
[    0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x00000000fbdfffff]
[    0.000000] NUMA: NODE_DATA [mem 0xfb610b00-0xfb612fff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000080000000-0x00000000fbdfffff]
[    0.000000]   DMA32    empty
[    0.000000]   Normal   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000080000000-0x00000000f7ffffff]
[    0.000000]   node   0: [mem 0x00000000fb000000-0x00000000fb7fffff]
[    0.000000]   node   0: [mem 0x00000000fbc00000-0x00000000fbdfffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x00000000fbdfffff]
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv0.2 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: Trusted OS migration not required
[    0.000000] percpu: Embedded 24 pages/cpu s60120 r8192 d29992 u98304
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: detected: ARM erratum 845719
[    0.000000] CPU features: kernel page table isolation forced ON by KASLR
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 486152
[    0.000000] Policy zone: DMA
[    0.000000] Kernel command line: console=ttyS0,115200 earlycon=uart8250,mmio,0x21c0500 root=PARTUUID=b5fc3971-04 rw rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[    0.000000] Memory: 1861936K/1976320K available (20416K kernel code, 3074K rwdata, 9944K rodata, 6656K init, 1035K bss, 81616K reserved, 32768K cma-reserved)
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=16 to nr_cpu_ids=4.
[    0.000000]  Trampoline variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x000000000142f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] random: get_random_bytes called from start_kernel+0x32c/0x4f0 with crng_init=0
[    0.000000] arch_timer: Enabling global workaround for Freescale erratum a005858
[    0.000000] arch_timer: CPU0: Trapping CNTVCT access
[    0.000000] arch_timer: cp15 timer(s) running at 25.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x5c40939b5, max_idle_ns: 440795202646 ns
[    0.000003] sched_clock: 56 bits at 25MHz, resolution 40ns, wraps every 4398046511100ns
[    0.009016] Console: colour dummy device 80x25
[    0.013537] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[    0.023945] pid_max: default: 32768 minimum: 301
[    0.028659] LSM: Security Framework initializing
[    0.033373] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.040816] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.049675] rcu: Hierarchical SRCU implementation.
[    0.056350] EFI services will not be available.
[    0.061033] smp: Bringing up secondary CPUs ...
[    0.065888] Detected VIPT I-cache on CPU1
[    0.065914] arch_timer: CPU1: Trapping CNTVCT access
[    0.065923] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.066253] Detected VIPT I-cache on CPU2
[    0.066268] arch_timer: CPU2: Trapping CNTVCT access
[    0.066275] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.066581] Detected VIPT I-cache on CPU3
[    0.066596] arch_timer: CPU3: Trapping CNTVCT access
[    0.066602] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.066643] smp: Brought up 1 node, 4 CPUs
[    0.117453] SMP: Total of 4 processors activated.
[    0.122181] CPU features: detected: 32-bit EL0 Support
[    0.127353] CPU features: detected: CRC32 instructions
[    0.132517] CPU features: detected: 32-bit EL1 Support
[    0.146291] CPU: All CPU(s) started at EL2
[    0.150418] alternatives: patching kernel code
[    0.155994] devtmpfs: initialized
[    0.163600] KASLR enabled
[    0.166332] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.176133] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.183836] pinctrl core: initialized pinctrl subsystem
[    0.189950] DMI not present or invalid.
[    0.194156] NET: Registered protocol family 16
[    0.199799] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.206982] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.214894] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.222881] audit: initializing netlink subsys (disabled)
[    0.228387] audit: type=2000 audit(0.168:1): state=initialized audit_enabled=0 res=1
[    0.229159] thermal_sys: Registered thermal governor 'step_wise'
[    0.236173] thermal_sys: Registered thermal governor 'power_allocator'
[    0.242584] cpuidle: using governor menu
[    0.253154] Bman ver:0a02,02,01
[    0.257730] qman-fqd addr 0x00000000fb800000 size 0x400000
[    0.263241] qman-pfdr addr 0x00000000f8000000 size 0x2000000
[    0.268929] Qman ver:0a01,03,02,00
[    0.272532] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.279402] ASID allocator initialised with 32768 entries
[    0.285859] Serial: AMBA PL011 UART driver
[    0.290045] imx mu driver is registered.
[    0.294012] imx rpmsg driver is registered.
[    0.325556] Machine: LS1043A RDB Board
[    0.329326] SoC family: QorIQ LS1043A
[    0.332999] SoC ID: svr:0x87920011, Revision: 1.1
[    0.359761] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.366507] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.373259] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.379993] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.387726] cryptd: max_cpu_qlen set to 1000
[    0.458813] raid6: neonx8   gen()  2848 MB/s
[    0.531158] raid6: neonx8   xor()  2133 MB/s
[    0.603507] raid6: neonx4   gen()  2928 MB/s
[    0.675852] raid6: neonx4   xor()  2112 MB/s
[    0.748209] raid6: neonx2   gen()  2797 MB/s
[    0.820551] raid6: neonx2   xor()  1961 MB/s
[    0.892934] raid6: neonx1   gen()  2431 MB/s
[    0.965276] raid6: neonx1   xor()  1657 MB/s
[    1.037622] raid6: int64x8  gen()  1987 MB/s
[    1.109966] raid6: int64x8  xor()  1046 MB/s
[    1.182321] raid6: int64x4  gen()  2222 MB/s
[    1.254662] raid6: int64x4  xor()  1105 MB/s
[    1.327014] raid6: int64x2  gen()  1888 MB/s
[    1.399358] raid6: int64x2  xor()   973 MB/s
[    1.471715] raid6: int64x1  gen()  1405 MB/s
[    1.544068] raid6: int64x1  xor()   746 MB/s
[    1.548356] raid6: using algorithm neonx4 gen() 2928 MB/s
[    1.553780] raid6: .... xor() 2112 MB/s, rmw enabled
[    1.558766] raid6: using neon recovery algorithm
[    1.564212] ACPI: Interpreter disabled.
[    1.571525] iommu: Default domain type: Passthrough
[    1.576682] vgaarb: loaded
[    1.579588] SCSI subsystem initialized
[    1.583574] usbcore: registered new interface driver usbfs
[    1.589114] usbcore: registered new interface driver hub
[    1.594468] usbcore: registered new device driver usb
[    1.600505] i2c i2c-0: IMX I2C adapter registered
[    1.605263] i2c i2c-0: using dma0chan16 (tx) and dma0chan17 (rx) for DMA transfers
[    1.613813] mc: Linux media interface: v0.10
[    1.618118] videodev: Linux video capture interface: v2.00
[    1.623691] pps_core: LinuxPPS API ver. 1 registered
[    1.628680] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.637879] PTP clock support registered
[    1.641957] EDAC MC: Ver: 3.0.0
[    1.646256] bman-fbpr addr 0x00000000fa000000 size 0x1000000
[    1.651967] Bman err interrupt handler present
[    1.657054] Bman portal initialised, cpu 0
[    1.661258] Bman portal initialised, cpu 1
[    1.665458] Bman portal initialised, cpu 2
[    1.669659] Bman portal initialised, cpu 3
[    1.673778] Bman portals initialised
[    1.678245] Qman err interrupt handler present
[    1.682912] QMan: Allocated lookup table at (____ptrval____), entry count 65537
[    1.690804] Qman portal initialised, cpu 0
[    1.695002] Qman portal initialised, cpu 1
[    1.699196] Qman portal initialised, cpu 2
[    1.703393] Qman portal initialised, cpu 3
[    1.707507] Qman portals initialised
[    1.711169] Bman: BPID allocator includes range 32:32
[    1.716301] Qman: FQID allocator includes range 256:256
[    1.721552] Qman: FQID allocator includes range 32768:32768
[    1.727203] Qman: CGRID allocator includes range 0:256
[    1.732512] Qman: pool channel allocator includes range 1025:15
[    1.738555] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[    1.745013] fsl-ifc 1530000.ifc: Freescale Integrated Flash Controller
[    1.751589] fsl-ifc 1530000.ifc: IFC version 1.4, 8 banks
[    1.757183] FPGA manager framework
[    1.760652] Advanced Linux Sound Architecture Driver Initialized.
[    1.767936] clocksource: Switched to clocksource arch_sys_counter
[    1.774206] VFS: Disk quotas dquot_6.6.0
[    1.778187] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.785219] pnp: PnP ACPI: disabled
[    1.793197] NET: Registered protocol family 2
[    1.797953] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    1.806549] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.814586] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.822105] TCP: Hash tables configured (established 16384 bind 16384)
[    1.828749] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.835516] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.842790] NET: Registered protocol family 1
[    1.847398] RPC: Registered named UNIX socket transport module.
[    1.853360] RPC: Registered udp transport module.
[    1.858086] RPC: Registered tcp transport module.
[    1.862812] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.869289] PCI: CLS 0 bytes, default 64
[    1.873841] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.882197] kvm [1]: IPA Size Limit: 40 bits
[    1.887657] kvm [1]: vgic interrupt IRQ9
[    1.891686] kvm [1]: Hyp mode initialized successfully
[    1.899107] Initialise system trusted keyrings
[    1.903647] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[    1.910476] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.916497] NFS: Registering the id_resolver key type
[    1.921584] Key type id_resolver registered
[    1.925787] Key type id_legacy registered
[    1.929830] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.936567] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.944015] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[    1.950309] fuse: init (API version 7.32)
[    1.954427] 9p: Installing v9fs 9p2000 file system support
[    1.987078] xor: measuring software checksum speed
[    1.994923]    8regs           :  3254 MB/sec
[    2.001932]    32regs          :  3738 MB/sec
[    2.009421]    arm64_neon      :  3164 MB/sec
[    2.013796] xor: using function: 32regs (3738 MB/sec)
[    2.018874] Key type asymmetric registered
[    2.022988] Asymmetric key parser 'x509' registered
[    2.027906] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    2.035407] io scheduler mq-deadline registered
[    2.039962] io scheduler kyber registered
[    2.059885] layerscape-pcie 3500000.pcie: host bridge /soc/pcie@3500000 ranges:
[    2.067254] layerscape-pcie 3500000.pcie:       IO 0x4800010000..0x480001ffff -> 0x0000000000
[    2.075834] layerscape-pcie 3500000.pcie:      MEM 0x4840000000..0x487fffffff -> 0x0040000000
[    2.084517] layerscape-pcie 3500000.pcie: PCI host bridge to bus 0000:00
[    2.091259] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.096773] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.102987] pci_bus 0000:00: root bus resource [mem 0x4840000000-0x487fffffff] (bus address [0x40000000-0x7fffffff])
[    2.113586] pci 0000:00:00.0: [1957:8080] type 01 class 0x060400
[    2.119636] pci 0000:00:00.0: reg 0x38: [mem 0x4840000000-0x48400007ff pref]
[    2.126754] pci 0000:00:00.0: supports D1 D2
[    2.131046] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[    2.140167] pci 0000:00:00.0: BAR 6: assigned [mem 0x4840000000-0x48400007ff pref]
[    2.147781] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.153201] pcieport 0000:00:00.0: PME: Signaling with IRQ 70
[    2.159126] layerscape-pcie 3600000.pcie: host bridge /soc/pcie@3600000 ranges:
[    2.166489] layerscape-pcie 3600000.pcie:       IO 0x5000010000..0x500001ffff -> 0x0000000000
[    2.175070] layerscape-pcie 3600000.pcie:      MEM 0x5040000000..0x507fffffff -> 0x0040000000
[    2.183728] layerscape-pcie 3600000.pcie: PCI host bridge to bus 0001:00
[    2.190467] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.195983] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x0000-0xffff])
[    2.204993] pci_bus 0001:00: root bus resource [mem 0x5040000000-0x507fffffff] (bus address [0x40000000-0x7fffffff])
[    2.215588] pci 0001:00:00.0: [1957:8080] type 01 class 0x060400
[    2.221636] pci 0001:00:00.0: reg 0x38: [mem 0x5040000000-0x50400007ff pref]
[    2.228744] pci 0001:00:00.0: supports D1 D2
[    2.233035] pci 0001:00:00.0: PME# supported from D0 D1 D2 D3hot
[    2.242096] pci 0001:00:00.0: BAR 6: assigned [mem 0x5040000000-0x50400007ff pref]
[    2.249708] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    2.255083] pcieport 0001:00:00.0: PME: Signaling with IRQ 72
[    2.262522] EINJ: ACPI disabled.
[    2.276067] Bus freq driver module loaded
[    2.289188] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.297609] printk: console [ttyS0] disabled
[    2.301946] 21c0500.serial: ttyS0 at MMIO 0x21c0500 (irq = 46, base_baud = 25000000) is a 16550A
[    2.310809] printk: console [ttyS0] enabled
[    2.319185] printk: bootconsole [uart8250] disabled
[    2.329285] 21c0600.serial: ttyS1 at MMIO 0x21c0600 (irq = 46, base_baud = 25000000) is a 16550A
[    2.338380] 21d0500.serial: ttyS2 at MMIO 0x21d0500 (irq = 47, base_baud = 25000000) is a 16550A
[    2.347473] 21d0600.serial: ttyS3 at MMIO 0x21d0600 (irq = 47, base_baud = 25000000) is a 16550A
[    2.356915] SuperH (H)SCI(F) driver initialized
[    2.362275] msm_serial: driver initialized
[    2.379296] brd: module loaded
[    2.386851] loop: module loaded
[    2.391256] megasas: 07.714.04.00-rc1
[    2.396303] imx ahci driver is registered.
[    2.400891] ahci-qoriq 3200000.sata: supply ahci not found, using dummy regulator
[    2.408444] ahci-qoriq 3200000.sata: supply phy not found, using dummy regulator
[    2.415870] ahci-qoriq 3200000.sata: supply target not found, using dummy regulator
[    2.423614] ahci-qoriq 3200000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[    2.432572] ahci-qoriq 3200000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    2.442851] scsi host0: ahci-qoriq
[    2.446422] ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x100 irq 57
[    2.455151] physmap-flash 60000000.nor: physmap platform flash device: [mem 0x60000000-0x67ffffff]
[    2.464154] 60000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x00227e
[    2.474154] Amd/Fujitsu Extended Query Table at 0x0040
[    2.479297]   Amd/Fujitsu Extended Query version 1.3.
[    2.484343] number of CFI chips: 1
[    2.493305] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac
[    2.499659] nand: Micron MT29F4G08ABBDAH4
[    2.503665] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    2.511501] Bad block table found at page 262080, version 0x01
[    2.517808] Bad block table found at page 262016, version 0x01
[    2.528373] fsl,ifc-nand 7e800000.nand: IFC NAND device at 0x7e800000, bank 1
[    2.537284] spi-nor spi0.0: found n25q128a11, expected n25q128a13
[    2.544591] spi-nor spi0.0: n25q128a11 (16384 Kbytes)
[    2.555548] libphy: Fixed MDIO Bus: probed
[    2.560857] tun: Universal TUN/TAP device driver, 1.6
[    2.566930] thunder_xcv, ver 1.0
[    2.570190] thunder_bgx, ver 1.0
[    2.573437] nicpf, ver 1.0
[    2.576867] libphy: Freescale XGMAC MDIO Bus: probed
[    2.586309] libphy: Freescale XGMAC MDIO Bus: probed
[    2.595217] libphy: Freescale XGMAC MDIO Bus: probed
[    2.600640] libphy: Freescale XGMAC MDIO Bus: probed
[    2.606059] libphy: Freescale XGMAC MDIO Bus: probed
[    2.611470] libphy: Freescale XGMAC MDIO Bus: probed
[    2.616887] libphy: Freescale XGMAC MDIO Bus: probed
[    2.622309] libphy: Freescale XGMAC MDIO Bus: probed
[    2.627725] libphy: Freescale XGMAC MDIO Bus: probed
[    2.645030] Freescale FM module, FMD API version 21.1.0
[    2.653365] Freescale FM Ports module
[    2.657026] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[    2.663113] fsl_mac 1ae0000.ethernet: FMan MEMAC
[    2.667732] fsl_mac 1ae0000.ethernet: FMan MAC address: 00:04:9f:07:21:8f
[    2.674890] fsl_mac 1ae2000.ethernet: FMan MEMAC
[    2.679508] fsl_mac 1ae2000.ethernet: FMan MAC address: 00:04:9f:07:21:90
[    2.686398] fsl_mac 1ae4000.ethernet: FMan MEMAC
[    2.691014] fsl_mac 1ae4000.ethernet: FMan MAC address: 00:04:9f:07:21:91
[    2.697919] fsl_mac 1ae6000.ethernet: FMan MEMAC
[    2.702536] fsl_mac 1ae6000.ethernet: FMan MAC address: 00:04:9f:07:21:92
[    2.709676] fsl_mac 1ae8000.ethernet: FMan MEMAC
[    2.714292] fsl_mac 1ae8000.ethernet: FMan MAC address: 00:04:9f:07:21:93
[    2.721435] fsl_mac 1aea000.ethernet: FMan MEMAC
[    2.726052] fsl_mac 1aea000.ethernet: FMan MAC address: 00:04:9f:07:21:94
[    2.732945] fsl_mac 1af0000.ethernet: FMan MEMAC
[    2.737562] fsl_mac 1af0000.ethernet: FMan MAC address: 00:04:9f:07:21:95
[    2.744391] fsl_dpa: FSL DPAA Ethernet driver
[    2.749228] fsl_dpa soc:fsl,dpaa:ethernet@0: Skip RX PCD High Priority FQs initialization
[    2.759156] fsl_dpa: fsl_dpa: Probed interface eth0
[    2.764451] fsl_dpa soc:fsl,dpaa:ethernet@1: Skip RX PCD High Priority FQs initialization
[    2.770114] ata1: SATA link down (SStatus 0 SControl 300)
[    2.774399] fsl_dpa: fsl_dpa: Probed interface eth1
[    2.783355] fsl_dpa soc:fsl,dpaa:ethernet@2: Skip RX PCD High Priority FQs initialization
[    2.793358] fsl_dpa: fsl_dpa: Probed interface eth2
[    2.798757] fsl_dpa soc:fsl,dpaa:ethernet@3: Skip RX PCD High Priority FQs initialization
[    2.808808] fsl_dpa: fsl_dpa: Probed interface eth3
[    2.814260] fsl_dpa soc:fsl,dpaa:ethernet@4: Skip RX PCD High Priority FQs initialization
[    2.824379] fsl_dpa: fsl_dpa: Probed interface eth4
[    2.829882] fsl_dpa soc:fsl,dpaa:ethernet@5: Skip RX PCD High Priority FQs initialization
[    2.840076] fsl_dpa: fsl_dpa: Probed interface eth5
[    2.845634] fsl_dpa soc:fsl,dpaa:ethernet@8: Skip RX PCD High Priority FQs initialization
[    2.855895] fsl_dpa: fsl_dpa: Probed interface eth6
[    2.860815] fsl_advanced: FSL DPAA Advanced drivers:
[    2.865775] fsl_proxy: FSL DPAA Proxy initialization driver
[    2.871587] fsl_oh: FSL FMan Offline Parsing port driver
[    2.877876] hclge is initializing
[    2.881197] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.888414] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.893751] e1000: Intel(R) PRO/1000 Network Driver
[    2.898626] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    2.904393] e1000e: Intel(R) PRO/1000 Network Driver
[    2.909352] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.915293] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.920686] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.926276] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    2.932538] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.938872] sky2: driver version 1.30
[    2.944141] usbcore: registered new interface driver r8152
[    2.949642] usbcore: registered new interface driver asix
[    2.955053] usbcore: registered new interface driver ax88179_178a
[    2.961556] VFIO - User Level meta-driver version: 0.3
[    2.970438] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.976966] ehci-pci: EHCI PCI platform driver
[    2.981428] ehci-platform: EHCI generic platform driver
[    2.986823] ehci-orion: EHCI orion driver
[    2.990954] ehci-exynos: EHCI Exynos driver
[    2.995239] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.001421] ohci-pci: OHCI PCI platform driver
[    3.005891] ohci-platform: OHCI generic platform driver
[    3.011262] ohci-exynos: OHCI Exynos driver
[    3.016053] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.021545] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.029273] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
[    3.038690] xhci-hcd xhci-hcd.0.auto: irq 55, io mem 0x02f00000
[    3.045062] hub 1-0:1.0: USB hub found
[    3.048825] hub 1-0:1.0: 1 port detected
[    3.052927] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.058414] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.066072] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.072897] hub 2-0:1.0: USB hub found
[    3.076656] hub 2-0:1.0: 1 port detected
[    3.080822] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.086312] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    3.094020] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
[    3.103429] xhci-hcd xhci-hcd.1.auto: irq 56, io mem 0x03000000
[    3.109721] hub 3-0:1.0: USB hub found
[    3.113482] hub 3-0:1.0: 1 port detected
[    3.117565] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.123051] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    3.130708] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    3.137526] hub 4-0:1.0: USB hub found
[    3.141285] hub 4-0:1.0: 1 port detected
[    3.145780] usbcore: registered new interface driver uas
[    3.151146] usbcore: registered new interface driver usb-storage
[    3.160876] ftm-alarm 29d0000.timer: registered as rtc1
[    3.167297] i2c /dev entries driver
[    3.173957] ptp_qoriq: device tree node missing required elements, try automatic configuration
[    3.182651] pps pps0: new PPS source ptp0
[    3.200978] random: fast init done
[    3.215343] qoriq-cpufreq qoriq-cpufreq: Freescale QorIQ CPU frequency scaling driver
[    3.224255] sdhci: Secure Digital Host Controller Interface driver
[    3.230433] sdhci: Copyright(c) Pierre Ossman
[    3.235491] Synopsys Designware Multimedia Card Interface Driver
[    3.242910] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.251165] ledtrig-cpu: registered to indicate activity on CPUs
[    3.258570] usbcore: registered new interface driver usbhid
[    3.264146] usbhid: USB HID core driver
[    3.269546] Freescale USDPAA process driver
[    3.273732] fsl-usdpaa: no region found
[    3.275598] mmc0: SDHCI controller on 1560000.esdhc [1560000.esdhc] using ADMA 64-bit
[    3.277562] Freescale USDPAA process IRQ driver
[    3.282539] optee: probing for conduit method.
[    3.294367] optee: api uid mismatch
[    3.297858] optee: probe of firmware:optee failed with error -22
[    3.311580] NET: Registered protocol family 26
[    3.316069] u32 classifier
[    3.318792]     input device check on
[    3.322452]     Actions configured
[    3.326280] Initializing XFRM netlink socket
[    3.330603] NET: Registered protocol family 10
[    3.335753] Segment Routing with IPv6
[    3.339460] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.345702] NET: Registered protocol family 17
[    3.350155] NET: Registered protocol family 15
[    3.354630] Bridge firewalling registered
[    3.358754] 8021q: 802.1Q VLAN Support v1.8
[    3.362959] lib80211: common routines for IEEE802.11 drivers
[    3.368659] 9pnet: Installing 9P2000 support
[    3.372951] tsn generic netlink module v1 init...
[    3.377699] Key type dns_resolver registered
[    3.382256] registered taskstats version 1
[    3.386355] Loading compiled-in X.509 certificates
[    3.392130] Btrfs loaded, crc32c=crc32c-generic
[    3.399568] ALSA device list:
[    3.402549]   No soundcards found.
[    3.406174] Waiting for root device PARTUUID=b5fc3971-04...
[    3.564899] random: crng init done
After the "random: crng init done" part it hangs forever. Can somebody help me to discover what is wrong?
ufedor
boot from vBank 4
 This means that NOR Flash is used for booting.
conara
Thank you for your response. But what is the correct source to boot from in case of a usb stick?
From the documentation:
Boot source          SW3[1:8] SW4[1:8] SW5[1:8]
NOR bank 0 (default) 10110011 00010010 10100010
NOR bank 4           10110011 00010010 10100110
SD card              10110011 00100000 00100010
NAND                 10110011 10000010 10100110
I cannot see a usb/removable storage device source.
Besides this I though that uboot is located in nor flash and it boots further from the usb stick. What is the reason it search for USB sticks and if it found one that it tries to boot from it?
USB device 0:
Scanning usb 0:1...
Scanning usb 0:2...
ufedor
Booting directly from USB is not supported.
To boot LSDK userland from the specified USB/SD/SATA storage device under U-Boot:
=> run bootcmd_usb0
conara
Thanks @ufedor , but it still doesn't boot. Can you take another look?
I did as you suggested:
1. Put the usb stick in usb2 (usb1 didn't work at all, see the bottom of my post).
2. Boot the device and interrupt the auto boot process.
3. run bootcmd_usb0
Output:
       CPU3(A53):1600 MHz
Board: LS1043ARDB, boot from vBank 0
CPLD:  V2.0
PCBA:  V6.0
I2C:   ready
Flash: 128 MiB
NAND:  512 MiB
MMC:   FSL_SDHC: 0
EEPROM: NXID v1
In:    serial
Out:   serial
Err:   serial
=> run bootcmd_usb0
starting USB...
USB XHCI 1.00
USB XHCI 1.00
USB XHCI 1.00
USB device 0:
Scanning usb 0:1...
Scanning usb 0:2...
39769 bytes read in 332 ms (116.2 KiB/s)
Starting kernel ...
[    0.000000] Memory: 1861932K/1976320K available (20416K kernel code, 3074K rwdata, 9944K rodata, 6656K init, 1035K bss, 81620K reserved, 32768K cma-reserved)
[    0.009017] Console: colour dummy device 80x25
[    0.013538] Calibrating delay loop (skipped), value calculated using timer frequency.. 50.00 BogoMIPS (lpj=100000)
[    0.023947] pid_max: default: 32768 minimum: 301
[    0.028660] LSM: Security Framework initializing
[    0.033374] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[    0.049670] rcu: Hierarchical SRCU implementation.
[    0.056345] EFI services will not be available.
[    0.061027] smp: Bringing up secondary CPUs ...
[    0.065882] Detected VIPT I-cache on CPU1
[    0.065908] arch_timer: CPU1: Trapping CNTVCT access
[    0.065917] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.066244] Detected VIPT I-cache on CPU2
[    0.066259] arch_timer: CPU2: Trapping CNTVCT access
[    0.066266] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.066572] Detected VIPT I-cache on CPU3
[    0.066586] arch_timer: CPU3: Trapping CNTVCT access
[    0.066593] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.066633] smp: Brought up 1 node, 4 CPUs
[    0.117443] SMP: Total of 4 processors activated.
[    0.122171] CPU features: detected: 32-bit EL0 Support
[    0.127343] CPU features: detected: CRC32 instructions
[    0.132508] CPU features: detected: 32-bit EL1 Support
[    0.146281] CPU: All CPU(s) started at EL2
[    0.150409] alternatives: patching kernel code
[    0.155988] devtmpfs: initialized
[    0.163585] KASLR enabled
[    0.166317] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.176118] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.183822] pinctrl core: initialized pinctrl subsystem
[    0.189926] DMI not present or invalid.
[    0.194134] NET: Registered protocol family 16
[    0.199777] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[    0.206961] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.214872] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.222860] audit: initializing netlink subsys (disabled)
[    0.228365] audit: type=2000 audit(0.168:1): state=initialized audit_enabled=0 res=1
[    0.229134] thermal_sys: Registered thermal governor 'step_wise'
[    0.236151] thermal_sys: Registered thermal governor 'power_allocator'
[    0.242560] cpuidle: using governor menu
[    0.253130] Bman ver:0a02,02,01
[    0.257707] qman-fqd addr 0x00000000fb800000 size 0x400000
[    0.263218] qman-pfdr addr 0x00000000f8000000 size 0x2000000
[    0.268906] Qman ver:0a01,03,02,00
[    0.272509] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.279381] ASID allocator initialised with 32768 entries
[    0.285838] Serial: AMBA PL011 UART driver
[    0.290023] imx mu driver is registered.
[    0.293990] imx rpmsg driver is registered.
[    0.325535] Machine: LS1043A RDB Board
[    0.329305] SoC family: QorIQ LS1043A
[    0.332978] SoC ID: svr:0x87920011, Revision: 1.1
[    0.359715] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.366460] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[    0.373212] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.379947] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[    0.387683] cryptd: max_cpu_qlen set to 1000
[    0.458785] raid6: neonx8   gen()  2871 MB/s
[    0.531129] raid6: neonx8   xor()  2135 MB/s
[    0.603483] raid6: neonx4   gen()  2946 MB/s
[    0.675826] raid6: neonx4   xor()  2117 MB/s
[    0.748174] raid6: neonx2   gen()  2795 MB/s
[    0.820519] raid6: neonx2   xor()  1964 MB/s
[    0.892898] raid6: neonx1   gen()  2428 MB/s
[    0.965241] raid6: neonx1   xor()  1663 MB/s
[    1.037591] raid6: int64x8  gen()  1987 MB/s
[    1.109936] raid6: int64x8  xor()  1046 MB/s
[    1.182287] raid6: int64x4  gen()  2221 MB/s
[    1.254627] raid6: int64x4  xor()  1104 MB/s
[    1.326982] raid6: int64x2  gen()  1889 MB/s
[    1.399328] raid6: int64x2  xor()   973 MB/s
[    1.471687] raid6: int64x1  gen()  1403 MB/s
[    1.544042] raid6: int64x1  xor()   746 MB/s
[    1.548330] raid6: using algorithm neonx4 gen() 2946 MB/s
[    1.553753] raid6: .... xor() 2117 MB/s, rmw enabled
[    1.558740] raid6: using neon recovery algorithm
[    1.564186] ACPI: Interpreter disabled.
[    1.571496] iommu: Default domain type: Passthrough
[    1.576651] vgaarb: loaded
[    1.579556] SCSI subsystem initialized
[    1.583542] usbcore: registered new interface driver usbfs
[    1.589083] usbcore: registered new interface driver hub
[    1.594437] usbcore: registered new device driver usb
[    1.600477] i2c i2c-0: IMX I2C adapter registered
[    1.605235] i2c i2c-0: using dma0chan16 (tx) and dma0chan17 (rx) for DMA transfers
[    1.613787] mc: Linux media interface: v0.10
[    1.618092] videodev: Linux video capture interface: v2.00
[    1.623666] pps_core: LinuxPPS API ver. 1 registered
[    1.628655] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.637853] PTP clock support registered
[    1.641931] EDAC MC: Ver: 3.0.0
[    1.646229] bman-fbpr addr 0x00000000fa000000 size 0x1000000
[    1.651941] Bman err interrupt handler present
[    1.657021] Bman portal initialised, cpu 0
[    1.661224] Bman portal initialised, cpu 1
[    1.665424] Bman portal initialised, cpu 2
[    1.669624] Bman portal initialised, cpu 3
[    1.673743] Bman portals initialised
[    1.678209] Qman err interrupt handler present
[    1.682870] QMan: Allocated lookup table at (____ptrval____), entry count 65537
[    1.690760] Qman portal initialised, cpu 0
[    1.694958] Qman portal initialised, cpu 1
[    1.699151] Qman portal initialised, cpu 2
[    1.703348] Qman portal initialised, cpu 3
[    1.707463] Qman portals initialised
[    1.711125] Bman: BPID allocator includes range 32:32
[    1.716257] Qman: FQID allocator includes range 256:256
[    1.721508] Qman: FQID allocator includes range 32768:32768
[    1.727159] Qman: CGRID allocator includes range 0:256
[    1.732467] Qman: pool channel allocator includes range 1025:15
[    1.738511] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[    1.744964] fsl-ifc 1530000.ifc: Freescale Integrated Flash Controller
[    1.751541] fsl-ifc 1530000.ifc: IFC version 1.4, 8 banks
[    1.757135] FPGA manager framework
[    1.760605] Advanced Linux Sound Architecture Driver Initialized.
[    1.767885] clocksource: Switched to clocksource arch_sys_counter
[    1.774156] VFS: Disk quotas dquot_6.6.0
[    1.778137] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.785170] pnp: PnP ACPI: disabled
[    1.793143] NET: Registered protocol family 2
[    1.797899] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[    1.806495] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[    1.814533] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[    1.822053] TCP: Hash tables configured (established 16384 bind 16384)
[    1.828698] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.835465] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[    1.842738] NET: Registered protocol family 1
[    1.847343] RPC: Registered named UNIX socket transport module.
[    1.853304] RPC: Registered udp transport module.
[    1.858032] RPC: Registered tcp transport module.
[    1.862758] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.869234] PCI: CLS 0 bytes, default 64
[    1.873780] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.882135] kvm [1]: IPA Size Limit: 40 bits
[    1.887597] kvm [1]: vgic interrupt IRQ9
[    1.891627] kvm [1]: Hyp mode initialized successfully
[    1.899048] Initialise system trusted keyrings
[    1.903589] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[    1.910416] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    1.916436] NFS: Registering the id_resolver key type
[    1.921525] Key type id_resolver registered
[    1.925729] Key type id_legacy registered
[    1.929773] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.936510] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[    1.943955] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[    1.950251] fuse: init (API version 7.32)
[    1.954369] 9p: Installing v9fs 9p2000 file system support
[    1.986480] xor: measuring software checksum speed
[    1.994324]    8regs           :  3254 MB/sec
[    2.001334]    32regs          :  3738 MB/sec
[    2.008822]    arm64_neon      :  3163 MB/sec
[    2.013197] xor: using function: 32regs (3738 MB/sec)
[    2.018276] Key type asymmetric registered
[    2.022390] Asymmetric key parser 'x509' registered
[    2.027308] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[    2.034807] io scheduler mq-deadline registered
[    2.039361] io scheduler kyber registered
[    2.059282] layerscape-pcie 3500000.pcie: host bridge /soc/pcie@3500000 ranges:
[    2.066652] layerscape-pcie 3500000.pcie:       IO 0x4800010000..0x480001ffff -> 0x0000000000
[    2.075231] layerscape-pcie 3500000.pcie:      MEM 0x4840000000..0x487fffffff -> 0x0040000000
[    2.083923] layerscape-pcie 3500000.pcie: PCI host bridge to bus 0000:00
[    2.090663] pci_bus 0000:00: root bus resource [bus 00-ff]
[    2.096177] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    2.102392] pci_bus 0000:00: root bus resource [mem 0x4840000000-0x487fffffff] (bus address [0x40000000-0x7fffffff])
[    2.112991] pci 0000:00:00.0: [1957:8080] type 01 class 0x060400
[    2.119042] pci 0000:00:00.0: reg 0x38: [mem 0x4840000000-0x48400007ff pref]
[    2.126158] pci 0000:00:00.0: supports D1 D2
[    2.130451] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[    2.139568] pci 0000:00:00.0: BAR 6: assigned [mem 0x4840000000-0x48400007ff pref]
[    2.147182] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[    2.152600] pcieport 0000:00:00.0: PME: Signaling with IRQ 70
[    2.158526] layerscape-pcie 3600000.pcie: host bridge /soc/pcie@3600000 ranges:
[    2.165889] layerscape-pcie 3600000.pcie:       IO 0x5000010000..0x500001ffff -> 0x0000000000
[    2.174470] layerscape-pcie 3600000.pcie:      MEM 0x5040000000..0x507fffffff -> 0x0040000000
[    2.183129] layerscape-pcie 3600000.pcie: PCI host bridge to bus 0001:00
[    2.189868] pci_bus 0001:00: root bus resource [bus 00-ff]
[    2.195384] pci_bus 0001:00: root bus resource [io  0x10000-0x1ffff] (bus address [0x0000-0xffff])
[    2.204397] pci_bus 0001:00: root bus resource [mem 0x5040000000-0x507fffffff] (bus address [0x40000000-0x7fffffff])
[    2.214988] pci 0001:00:00.0: [1957:8080] type 01 class 0x060400
[    2.221036] pci 0001:00:00.0: reg 0x38: [mem 0x5040000000-0x50400007ff pref]
[    2.228145] pci 0001:00:00.0: supports D1 D2
[    2.232436] pci 0001:00:00.0: PME# supported from D0 D1 D2 D3hot
[    2.241495] pci 0001:00:00.0: BAR 6: assigned [mem 0x5040000000-0x50400007ff pref]
[    2.249108] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[    2.254484] pcieport 0001:00:00.0: PME: Signaling with IRQ 72
[    2.261925] EINJ: ACPI disabled.
[    2.275444] Bus freq driver module loaded
[    2.288559] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    2.296985] printk: console [ttyS0] disabled
[    2.301322] 21c0500.serial: ttyS0 at MMIO 0x21c0500 (irq = 46, base_baud = 25000000) is a 16550A
[    2.310185] printk: console [ttyS0] enabled
[    2.318561] printk: bootconsole [uart8250] disabled
[    2.328671] 21c0600.serial: ttyS1 at MMIO 0x21c0600 (irq = 46, base_baud = 25000000) is a 16550A
[    2.337763] 21d0500.serial: ttyS2 at MMIO 0x21d0500 (irq = 47, base_baud = 25000000) is a 16550A
[    2.346856] 21d0600.serial: ttyS3 at MMIO 0x21d0600 (irq = 47, base_baud = 25000000) is a 16550A
[    2.356308] SuperH (H)SCI(F) driver initialized
[    2.361666] msm_serial: driver initialized
[    2.378643] brd: module loaded
[    2.386192] loop: module loaded
[    2.390598] megasas: 07.714.04.00-rc1
[    2.395625] imx ahci driver is registered.
[    2.400227] ahci-qoriq 3200000.sata: supply ahci not found, using dummy regulator
[    2.407780] ahci-qoriq 3200000.sata: supply phy not found, using dummy regulator
[    2.415205] ahci-qoriq 3200000.sata: supply target not found, using dummy regulator
[    2.422950] ahci-qoriq 3200000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[    2.431907] ahci-qoriq 3200000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[    2.442183] scsi host0: ahci-qoriq
[    2.445755] ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x100 irq 57
[    2.454488] physmap-flash 60000000.nor: physmap platform flash device: [mem 0x60000000-0x67ffffff]
[    2.463486] 60000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x00227e
[    2.473486] Amd/Fujitsu Extended Query Table at 0x0040
[    2.478631]   Amd/Fujitsu Extended Query version 1.3.
[    2.483678] number of CFI chips: 1
[    2.493255] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac
[    2.499608] nand: Micron MT29F4G08ABBDAH4
[    2.503613] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[    2.511448] Bad block table found at page 262080, version 0x01
[    2.517755] Bad block table found at page 262016, version 0x01
[    2.528341] fsl,ifc-nand 7e800000.nand: IFC NAND device at 0x7e800000, bank 1
[    2.537253] spi-nor spi0.0: found n25q128a11, expected n25q128a13
[    2.544553] spi-nor spi0.0: n25q128a11 (16384 Kbytes)
[    2.555497] libphy: Fixed MDIO Bus: probed
[    2.560807] tun: Universal TUN/TAP device driver, 1.6
[    2.566874] thunder_xcv, ver 1.0
[    2.570128] thunder_bgx, ver 1.0
[    2.573373] nicpf, ver 1.0
[    2.576814] libphy: Freescale XGMAC MDIO Bus: probed
[    2.586252] libphy: Freescale XGMAC MDIO Bus: probed
[    2.595162] libphy: Freescale XGMAC MDIO Bus: probed
[    2.600581] libphy: Freescale XGMAC MDIO Bus: probed
[    2.605996] libphy: Freescale XGMAC MDIO Bus: probed
[    2.611420] libphy: Freescale XGMAC MDIO Bus: probed
[    2.616837] libphy: Freescale XGMAC MDIO Bus: probed
[    2.622244] libphy: Freescale XGMAC MDIO Bus: probed
[    2.627673] libphy: Freescale XGMAC MDIO Bus: probed
[    2.644971] Freescale FM module, FMD API version 21.1.0
[    2.653332] Freescale FM Ports module
[    2.656995] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[    2.663078] fsl_mac 1ae0000.ethernet: FMan MEMAC
[    2.667697] fsl_mac 1ae0000.ethernet: FMan MAC address: 00:04:9f:07:21:8f
[    2.674845] fsl_mac 1ae2000.ethernet: FMan MEMAC
[    2.679463] fsl_mac 1ae2000.ethernet: FMan MAC address: 00:04:9f:07:21:90
[    2.686363] fsl_mac 1ae4000.ethernet: FMan MEMAC
[    2.690980] fsl_mac 1ae4000.ethernet: FMan MAC address: 00:04:9f:07:21:91
[    2.697883] fsl_mac 1ae6000.ethernet: FMan MEMAC
[    2.702500] fsl_mac 1ae6000.ethernet: FMan MAC address: 00:04:9f:07:21:92
[    2.709640] fsl_mac 1ae8000.ethernet: FMan MEMAC
[    2.714255] fsl_mac 1ae8000.ethernet: FMan MAC address: 00:04:9f:07:21:93
[    2.721394] fsl_mac 1aea000.ethernet: FMan MEMAC
[    2.726012] fsl_mac 1aea000.ethernet: FMan MAC address: 00:04:9f:07:21:94
[    2.732907] fsl_mac 1af0000.ethernet: FMan MEMAC
[    2.737524] fsl_mac 1af0000.ethernet: FMan MAC address: 00:04:9f:07:21:95
[    2.744352] fsl_dpa: FSL DPAA Ethernet driver
[    2.749183] fsl_dpa soc:fsl,dpaa:ethernet@0: Skip RX PCD High Priority FQs initialization
[    2.759117] fsl_dpa: fsl_dpa: Probed interface eth0
[    2.764419] fsl_dpa soc:fsl,dpaa:ethernet@1: Skip RX PCD High Priority FQs initialization
[    2.766100] ata1: SATA link down (SStatus 0 SControl 300)
[    2.774354] fsl_dpa: fsl_dpa: Probed interface eth1
[    2.783326] fsl_dpa soc:fsl,dpaa:ethernet@2: Skip RX PCD High Priority FQs initialization
[    2.793310] fsl_dpa: fsl_dpa: Probed interface eth2
[    2.798708] fsl_dpa soc:fsl,dpaa:ethernet@3: Skip RX PCD High Priority FQs initialization
[    2.808770] fsl_dpa: fsl_dpa: Probed interface eth3
[    2.814221] fsl_dpa soc:fsl,dpaa:ethernet@4: Skip RX PCD High Priority FQs initialization
[    2.824341] fsl_dpa: fsl_dpa: Probed interface eth4
[    2.829845] fsl_dpa soc:fsl,dpaa:ethernet@5: Skip RX PCD High Priority FQs initialization
[    2.840045] fsl_dpa: fsl_dpa: Probed interface eth5
[    2.845601] fsl_dpa soc:fsl,dpaa:ethernet@8: Skip RX PCD High Priority FQs initialization
[    2.855858] fsl_dpa: fsl_dpa: Probed interface eth6
[    2.860778] fsl_advanced: FSL DPAA Advanced drivers:
[    2.865738] fsl_proxy: FSL DPAA Proxy initialization driver
[    2.871548] fsl_oh: FSL FMan Offline Parsing port driver
[    2.877834] hclge is initializing
[    2.881155] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[    2.888371] hns3: Copyright (c) 2017 Huawei Corporation.
[    2.893703] e1000: Intel(R) PRO/1000 Network Driver
[    2.898575] e1000: Copyright (c) 1999-2006 Intel Corporation.
[    2.904345] e1000e: Intel(R) PRO/1000 Network Driver
[    2.909304] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[    2.915246] igb: Intel(R) Gigabit Ethernet Network Driver
[    2.920639] igb: Copyright (c) 2007-2014 Intel Corporation.
[    2.926227] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[    2.932489] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[    2.938823] sky2: driver version 1.30
[    2.944078] usbcore: registered new interface driver r8152
[    2.949582] usbcore: registered new interface driver asix
[    2.954993] usbcore: registered new interface driver ax88179_178a
[    2.961495] VFIO - User Level meta-driver version: 0.3
[    2.970383] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    2.976912] ehci-pci: EHCI PCI platform driver
[    2.981376] ehci-platform: EHCI generic platform driver
[    2.986771] ehci-orion: EHCI orion driver
[    2.990902] ehci-exynos: EHCI Exynos driver
[    2.995186] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.001368] ohci-pci: OHCI PCI platform driver
[    3.005829] ohci-platform: OHCI generic platform driver
[    3.011199] ohci-exynos: OHCI Exynos driver
[    3.015985] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.021477] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    3.029199] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
[    3.038616] xhci-hcd xhci-hcd.0.auto: irq 55, io mem 0x02f00000
[    3.045004] hub 1-0:1.0: USB hub found
[    3.048768] hub 1-0:1.0: 1 port detected
[    3.052872] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    3.058359] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    3.066015] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    3.072839] hub 2-0:1.0: USB hub found
[    3.076600] hub 2-0:1.0: 1 port detected
[    3.080765] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.086254] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[    3.093964] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
[    3.103371] xhci-hcd xhci-hcd.1.auto: irq 56, io mem 0x03000000
[    3.109653] hub 3-0:1.0: USB hub found
[    3.113415] hub 3-0:1.0: 1 port detected
[    3.117498] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[    3.122985] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[    3.130642] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[    3.136179] random: fast init done
[    3.137455] hub 4-0:1.0: USB hub found
[    3.144310] hub 4-0:1.0: 1 port detected
[    3.148799] usbcore: registered new interface driver uas
[    3.154165] usbcore: registered new interface driver usb-storage
[    3.163897] ftm-alarm 29d0000.timer: registered as rtc1
[    3.170317] i2c /dev entries driver
[    3.176967] ptp_qoriq: device tree node missing required elements, try automatic configuration
[    3.185672] pps pps0: new PPS source ptp0
[    3.218377] qoriq-cpufreq qoriq-cpufreq: Freescale QorIQ CPU frequency scaling driver
[    3.227239] sdhci: Secure Digital Host Controller Interface driver
[    3.233438] sdhci: Copyright(c) Pierre Ossman
[    3.238485] Synopsys Designware Multimedia Card Interface Driver
[    3.245918] sdhci-pltfm: SDHCI platform and OF driver helper
[    3.254182] ledtrig-cpu: registered to indicate activity on CPUs
[    3.261564] usbcore: registered new interface driver usbhid
[    3.267139] usbhid: USB HID core driver
[    3.272592] Freescale USDPAA process driver
[    3.276460] mmc0: SDHCI controller on 1560000.esdhc [1560000.esdhc] using ADMA 64-bit
[    3.276775] fsl-usdpaa: no region found
[    3.288419] Freescale USDPAA process IRQ driver
[    3.297930] optee: probing for conduit method.
[    3.302387] optee: api uid mismatch
[    3.305878] optee: probe of firmware:optee failed with error -22
[    3.319547] NET: Registered protocol family 26
[    3.324037] u32 classifier
[    3.326759]     input device check on
[    3.330419]     Actions configured
[    3.334246] Initializing XFRM netlink socket
[    3.338574] NET: Registered protocol family 10
[    3.343729] Segment Routing with IPv6
[    3.347437] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    3.353670] NET: Registered protocol family 17
[    3.358123] NET: Registered protocol family 15
[    3.362600] Bridge firewalling registered
[    3.366727] 8021q: 802.1Q VLAN Support v1.8
[    3.370936] lib80211: common routines for IEEE802.11 drivers
[    3.376633] 9pnet: Installing 9P2000 support
[    3.380924] tsn generic netlink module v1 init...
[    3.385671] Key type dns_resolver registered
[    3.390218] registered taskstats version 1
[    3.394317] Loading compiled-in X.509 certificates
[    3.400088] Btrfs loaded, crc32c=crc32c-generic
[    3.407514] ALSA device list:
[    3.410511]   No soundcards found.
[    3.414136] Waiting for root device PARTUUID=b5fc3971-04...
[    3.504616] random: crng init done
[   17.467924] xhci-hcd xhci-hcd.1.auto: Error while assigning device slot ID
[   17.474830] xhci-hcd xhci-hcd.1.auto: Max number of devices this xHCI host supports is 127.
[   17.483205] usb usb4-port1: couldn't allocate usb_device
Note: I also tried usb1, but in this usb port the usb stick is not recognized at all.
       CPU3(A53):1600 MHz
CPLD:  V2.0
PCBA:  V6.0
I2C:   ready
Flash: 128 MiB
NAND:  512 MiB
MMC:   FSL_SDHC: 0
EEPROM: NXID v1
In:    serial
Out:   serial
Err:   serial
=> run bootcmd_usb0
starting USB...
USB XHCI 1.00
USB XHCI 1.00
USB XHCI 1.00
scanning bus 1 for devices... 1 USB Device(s) found
       scanning usb for storage devices... 0 Storage Device(s) found
USB device 0: unknown device
Do you have any suggestions how to fix it?
EDIT:
I tried a SD card and this works out of the box. I created it the same way, but boots directly from the SD card. So why doesn't work the USB setup?
ufedor
Previously in the log:
USB device 0:
Which USB port was used?
conara
Thanks @ufedor , but it still doesn't boot correctly.
1. Put the usb stick in usb2 (port at the back of the device)
2. Start the board and interrupt auto boot. In bootloader run the following command: run bootcmd_usb0
Output:
CPU3(A53):1600 MHz
CPLD: V2.0
PCBA: V6.0
I2C: ready
Flash: 128 MiB
NAND: 512 MiB
MMC: FSL_SDHC: 0
EEPROM: NXID v1
In: serial
Out: serial
Err: serial
=> run bootcmd_usb0
starting USB...
USB XHCI 1.00
USB XHCI 1.00
USB XHCI 1.00
USB device 0:
Scanning usb 0:1...
Scanning usb 0:2...
Starting kernel ...
[ 0.040817] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.049673] rcu: Hierarchical SRCU implementation.
[ 0.056346] EFI services will not be available.
[ 0.061028] smp: Bringing up secondary CPUs ...
[ 0.065881] Detected VIPT I-cache on CPU1
[ 0.065907] arch_timer: CPU1: Trapping CNTVCT access
[ 0.065916] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.066260] arch_timer: CPU2: Trapping CNTVCT access
[ 0.066267] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.066573] Detected VIPT I-cache on CPU3
[ 0.066588] arch_timer: CPU3: Trapping CNTVCT access
[ 0.066595] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.066635] smp: Brought up 1 node, 4 CPUs
[ 0.117446] SMP: Total of 4 processors activated.
[ 0.122174] CPU features: detected: 32-bit EL0 Support
[ 0.127346] CPU features: detected: CRC32 instructions
[ 0.132511] CPU features: detected: 32-bit EL1 Support
[ 0.146282] CPU: All CPU(s) started at EL2
[ 0.163590] KASLR enabled
[ 0.166322] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.176123] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.189929] DMI not present or invalid.
[ 0.194137] NET: Registered protocol family 16
[ 0.199775] DMA: preallocated 256 KiB GFP_KERNEL pool for atomic allocations
[ 0.206959] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.214870] DMA: preallocated 256 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.222857] audit: initializing netlink subsys (disabled)
[ 0.228364] audit: type=2000 audit(0.168:1): state=initialized audit_enabled=0 res=1
[ 0.236150] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.242563] cpuidle: using governor menu
[ 0.253133] Bman ver:0a02,02,01
[ 0.272508] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.279380] ASID allocator initialised with 32768 entries
[ 0.285839] Serial: AMBA PL011 UART driver
[ 0.293991] imx rpmsg driver is registered.
[ 0.325527] Machine: LS1043A RDB Board
[ 0.329297] SoC family: QorIQ LS1043A
[ 0.332969] SoC ID: svr:0x87920011, Revision: 1.1
[ 0.366462] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.373214] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.379948] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.387681] cryptd: max_cpu_qlen set to 1000
[ 0.458788] raid6: neonx8 gen() 2848 MB/s
[ 0.531133] raid6: neonx8 xor() 2135 MB/s
[ 0.603489] raid6: neonx4 gen() 2924 MB/s
[ 0.675832] raid6: neonx4 xor() 2115 MB/s
[ 0.748184] raid6: neonx2 gen() 2795 MB/s
[ 0.820530] raid6: neonx2 xor() 1967 MB/s
[ 0.892908] raid6: neonx1 gen() 2431 MB/s
[ 0.965254] raid6: neonx1 xor() 1657 MB/s
[ 1.037600] raid6: int64x8 gen() 1987 MB/s
[ 1.109943] raid6: int64x8 xor() 1046 MB/s
[ 1.182300] raid6: int64x4 gen() 2222 MB/s
[ 1.254645] raid6: int64x4 xor() 1101 MB/s
[ 1.326999] raid6: int64x2 gen() 1889 MB/s
[ 1.399340] raid6: int64x2 xor() 969 MB/s
[ 1.544041] raid6: int64x1 xor() 746 MB/s
[ 1.548329] raid6: using algorithm neonx4 gen() 2924 MB/s
[ 1.553753] raid6: .... xor() 2115 MB/s, rmw enabled
[ 1.558739] raid6: using neon recovery algorithm
[ 1.564185] ACPI: Interpreter disabled.
[ 1.571494] iommu: Default domain type: Passthrough
[ 1.579558] SCSI subsystem initialized
[ 1.583544] usbcore: registered new interface driver usbfs
[ 1.589085] usbcore: registered new interface driver hub
[ 1.594439] usbcore: registered new device driver usb
[ 1.600484] i2c i2c-0: IMX I2C adapter registered
[ 1.605241] i2c i2c-0: using dma0chan16 (tx) and dma0chan17 (rx) for DMA transfers
[ 1.613793] mc: Linux media interface: v0.10
[ 1.618098] videodev: Linux video capture interface: v2.00
[ 1.623670] pps_core: LinuxPPS API ver. 1 registered
[ 1.628659] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 1.637857] PTP clock support registered
[ 1.641934] EDAC MC: Ver: 3.0.0
[ 1.646230] bman-fbpr addr 0x00000000fa000000 size 0x1000000
[ 1.651942] Bman err interrupt handler present
[ 1.657025] Bman portal initialised, cpu 0
[ 1.661229] Bman portal initialised, cpu 1
[ 1.665430] Bman portal initialised, cpu 2
[ 1.669631] Bman portal initialised, cpu 3
[ 1.673749] Bman portals initialised
[ 1.678214] Qman err interrupt handler present
[ 1.682881] QMan: Allocated lookup table at (____ptrval____), entry count 65537
[ 1.690771] Qman portal initialised, cpu 0
[ 1.694969] Qman portal initialised, cpu 1
[ 1.699162] Qman portal initialised, cpu 2
[ 1.703359] Qman portal initialised, cpu 3
[ 1.707474] Qman portals initialised
[ 1.711136] Bman: BPID allocator includes range 32:32
[ 1.716267] Qman: FQID allocator includes range 256:256
[ 1.721518] Qman: FQID allocator includes range 32768:32768
[ 1.727170] Qman: CGRID allocator includes range 0:256
[ 1.732478] Qman: pool channel allocator includes range 1025:15
[ 1.738523] No USDPAA memory, no 'fsl,usdpaa-mem' in device-tree
[ 1.744979] fsl-ifc 1530000.ifc: Freescale Integrated Flash Controller
[ 1.751556] fsl-ifc 1530000.ifc: IFC version 1.4, 8 banks
[ 1.757150] FPGA manager framework
[ 1.760619] Advanced Linux Sound Architecture Driver Initialized.
[ 1.767900] clocksource: Switched to clocksource arch_sys_counter
[ 1.774171] VFS: Disk quotas dquot_6.6.0
[ 1.778151] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.785185] pnp: PnP ACPI: disabled
[ 1.793150] NET: Registered protocol family 2
[ 1.797918] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes, linear)
[ 1.806515] TCP established hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 1.814553] TCP bind hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 1.822073] TCP: Hash tables configured (established 16384 bind 16384)
[ 1.828717] UDP hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 1.835484] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes, linear)
[ 1.842756] NET: Registered protocol family 1
[ 1.847364] RPC: Registered named UNIX socket transport module.
[ 1.853325] RPC: Registered udp transport module.
[ 1.858052] RPC: Registered tcp transport module.
[ 1.862778] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.869254] PCI: CLS 0 bytes, default 64
[ 1.873801] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 1.882156] kvm [1]: IPA Size Limit: 40 bits
[ 1.887626] kvm [1]: vgic interrupt IRQ9
[ 1.891654] kvm [1]: Hyp mode initialized successfully
[ 1.899071] Initialise system trusted keyrings
[ 1.903611] workingset: timestamp_bits=42 max_order=19 bucket_order=0
[ 1.910440] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 1.916459] NFS: Registering the id_resolver key type
[ 1.921548] Key type id_resolver registered
[ 1.925751] Key type id_legacy registered
[ 1.929795] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 1.936533] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 1.943979] jffs2: version 2.2. (NAND) �© 2001-2006 Red Hat, Inc.
[ 1.950272] fuse: init (API version 7.32)
[ 1.954390] 9p: Installing v9fs 9p2000 file system support
[ 1.986850] xor: measuring software checksum speed
[ 1.994694] 8regs : 3254 MB/sec
[ 2.001704] 32regs : 3738 MB/sec
[ 2.009192] arm64_neon : 3163 MB/sec
[ 2.013568] xor: using function: 32regs (3738 MB/sec)
[ 2.018646] Key type asymmetric registered
[ 2.022760] Asymmetric key parser 'x509' registered
[ 2.027679] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 243)
[ 2.035177] io scheduler mq-deadline registered
[ 2.039731] io scheduler kyber registered
[ 2.059644] layerscape-pcie 3500000.pcie: host bridge /soc/pcie@3500000 ranges:
[ 2.067014] layerscape-pcie 3500000.pcie: IO 0x4800010000..0x480001ffff -> 0x0000000000
[ 2.075595] layerscape-pcie 3500000.pcie: MEM 0x4840000000..0x487fffffff -> 0x0040000000
[ 2.084279] layerscape-pcie 3500000.pcie: PCI host bridge to bus 0000:00
[ 2.091020] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.096534] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.102748] pci_bus 0000:00: root bus resource [mem 0x4840000000-0x487fffffff] (bus address [0x40000000-0x7fffffff])
[ 2.113347] pci 0000:00:00.0: [1957:8080] type 01 class 0x060400
[ 2.119397] pci 0000:00:00.0: reg 0x38: [mem 0x4840000000-0x48400007ff pref]
[ 2.126515] pci 0000:00:00.0: supports D1 D2
[ 2.130808] pci 0000:00:00.0: PME# supported from D0 D1 D2 D3hot
[ 2.139929] pci 0000:00:00.0: BAR 6: assigned [mem 0x4840000000-0x48400007ff pref]
[ 2.147542] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
[ 2.152959] pcieport 0000:00:00.0: PME: Signaling with IRQ 70
[ 2.158884] layerscape-pcie 3600000.pcie: host bridge /soc/pcie@3600000 ranges:
[ 2.166248] layerscape-pcie 3600000.pcie: IO 0x5000010000..0x500001ffff -> 0x0000000000
[ 2.174828] layerscape-pcie 3600000.pcie: MEM 0x5040000000..0x507fffffff -> 0x0040000000
[ 2.183486] layerscape-pcie 3600000.pcie: PCI host bridge to bus 0001:00
[ 2.190226] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 2.195741] pci_bus 0001:00: root bus resource [io 0x10000-0x1ffff] (bus address [0x0000-0xffff])
[ 2.204751] pci_bus 0001:00: root bus resource [mem 0x5040000000-0x507fffffff] (bus address [0x40000000-0x7fffffff])
[ 2.215346] pci 0001:00:00.0: [1957:8080] type 01 class 0x060400
[ 2.221394] pci 0001:00:00.0: reg 0x38: [mem 0x5040000000-0x50400007ff pref]
[ 2.228502] pci 0001:00:00.0: supports D1 D2
[ 2.232794] pci 0001:00:00.0: PME# supported from D0 D1 D2 D3hot
[ 2.241852] pci 0001:00:00.0: BAR 6: assigned [mem 0x5040000000-0x50400007ff pref]
[ 2.249464] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 2.254839] pcieport 0001:00:00.0: PME: Signaling with IRQ 72
[ 2.262281] EINJ: ACPI disabled.
[ 2.275790] Bus freq driver module loaded
[ 2.288906] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 2.297330] printk: console [ttyS0] disabled
[ 2.301667] 21c0500.serial: ttyS0 at MMIO 0x21c0500 (irq = 46, base_baud = 25000000) is a 16550A
[ 2.310529] printk: console [ttyS0] enabled
[ 2.318905] printk: bootconsole [uart8250] disabled
[ 2.329002] 21c0600.serial: ttyS1 at MMIO 0x21c0600 (irq = 46, base_baud = 25000000) is a 16550A
[ 2.338097] 21d0500.serial: ttyS2 at MMIO 0x21d0500 (irq = 47, base_baud = 25000000) is a 16550A
[ 2.347191] 21d0600.serial: ttyS3 at MMIO 0x21d0600 (irq = 47, base_baud = 25000000) is a 16550A
[ 2.356633] SuperH (H)SCI(F) driver initialized
[ 2.361989] msm_serial: driver initialized
[ 2.378967] brd: module loaded
[ 2.386530] loop: module loaded
[ 2.390935] megasas: 07.714.04.00-rc1
[ 2.395977] imx ahci driver is registered.
[ 2.400563] ahci-qoriq 3200000.sata: supply ahci not found, using dummy regulator
[ 2.408115] ahci-qoriq 3200000.sata: supply phy not found, using dummy regulator
[ 2.415539] ahci-qoriq 3200000.sata: supply target not found, using dummy regulator
[ 2.423284] ahci-qoriq 3200000.sata: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl platform mode
[ 2.432242] ahci-qoriq 3200000.sata: flags: 64bit ncq sntf pm clo only pmp fbs pio slum part ccc sds apst
[ 2.442518] scsi host0: ahci-qoriq
[ 2.446090] ata1: SATA max UDMA/133 mmio [mem 0x03200000-0x0320ffff] port 0x100 irq 57
[ 2.454817] physmap-flash 60000000.nor: physmap platform flash device: [mem 0x60000000-0x67ffffff]
[ 2.463819] 60000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000089 Chip ID 0x00227e
[ 2.473820] Amd/Fujitsu Extended Query Table at 0x0040
[ 2.478963] Amd/Fujitsu Extended Query version 1.3.
[ 2.484009] number of CFI chips: 1
[ 2.493256] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac
[ 2.499614] nand: Micron MT29F4G08ABBDAH4
[ 2.503618] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 2.511455] Bad block table found at page 262080, version 0x01
[ 2.517765] Bad block table found at page 262016, version 0x01
[ 2.528360] fsl,ifc-nand 7e800000.nand: IFC NAND device at 0x7e800000, bank 1
[ 2.537280] spi-nor spi0.0: found n25q128a11, expected n25q128a13
[ 2.544594] spi-nor spi0.0: n25q128a11 (16384 Kbytes)
[ 2.559500] libphy: Fixed MDIO Bus: probed
[ 2.564810] tun: Universal TUN/TAP device driver, 1.6
[ 2.570880] thunder_xcv, ver 1.0
[ 2.574129] thunder_bgx, ver 1.0
[ 2.577375] nicpf, ver 1.0
[ 2.580817] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.590253] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.599177] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.604601] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.610015] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.615438] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.620848] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.626266] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.631690] libphy: Freescale XGMAC MDIO Bus: probed
[ 2.648993] Freescale FM module, FMD API version 21.1.0
[ 2.657314] Freescale FM Ports module
[ 2.660985] fsl_mac: fsl_mac: FSL FMan MAC API based driver
[ 2.667071] fsl_mac 1ae0000.ethernet: FMan MEMAC
[ 2.671691] fsl_mac 1ae0000.ethernet: FMan MAC address: 00:04:9f:07:21:8f
[ 2.678839] fsl_mac 1ae2000.ethernet: FMan MEMAC
[ 2.683455] fsl_mac 1ae2000.ethernet: FMan MAC address: 00:04:9f:07:21:90
[ 2.690346] fsl_mac 1ae4000.ethernet: FMan MEMAC
[ 2.694963] fsl_mac 1ae4000.ethernet: FMan MAC address: 00:04:9f:07:21:91
[ 2.701868] fsl_mac 1ae6000.ethernet: FMan MEMAC
[ 2.706486] fsl_mac 1ae6000.ethernet: FMan MAC address: 00:04:9f:07:21:92
[ 2.713637] fsl_mac 1ae8000.ethernet: FMan MEMAC
[ 2.718253] fsl_mac 1ae8000.ethernet: FMan MAC address: 00:04:9f:07:21:93
[ 2.725393] fsl_mac 1aea000.ethernet: FMan MEMAC
[ 2.730010] fsl_mac 1aea000.ethernet: FMan MAC address: 00:04:9f:07:21:94
[ 2.736904] fsl_mac 1af0000.ethernet: FMan MEMAC
[ 2.741520] fsl_mac 1af0000.ethernet: FMan MAC address: 00:04:9f:07:21:95
[ 2.748346] fsl_dpa: FSL DPAA Ethernet driver
[ 2.753186] fsl_dpa soc:fsl,dpaa:ethernet@0: Skip RX PCD High Priority FQs initialization
[ 2.763122] fsl_dpa: fsl_dpa: Probed interface eth0
[ 2.767196] ata1: SATA link down (SStatus 0 SControl 300)
[ 2.768421] fsl_dpa soc:fsl,dpaa:ethernet@1: Skip RX PCD High Priority FQs initialization
[ 2.783336] fsl_dpa: fsl_dpa: Probed interface eth1
[ 2.788677] fsl_dpa soc:fsl,dpaa:ethernet@2: Skip RX PCD High Priority FQs initialization
[ 2.798657] fsl_dpa: fsl_dpa: Probed interface eth2
[ 2.804060] fsl_dpa soc:fsl,dpaa:ethernet@3: Skip RX PCD High Priority FQs initialization
[ 2.814111] fsl_dpa: fsl_dpa: Probed interface eth3
[ 2.819560] fsl_dpa soc:fsl,dpaa:ethernet@4: Skip RX PCD High Priority FQs initialization
[ 2.829677] fsl_dpa: fsl_dpa: Probed interface eth4
[ 2.835184] fsl_dpa soc:fsl,dpaa:ethernet@5: Skip RX PCD High Priority FQs initialization
[ 2.845379] fsl_dpa: fsl_dpa: Probed interface eth5
[ 2.850940] fsl_dpa soc:fsl,dpaa:ethernet@8: Skip RX PCD High Priority FQs initialization
[ 2.861215] fsl_dpa: fsl_dpa: Probed interface eth6
[ 2.866133] fsl_advanced: FSL DPAA Advanced drivers:
[ 2.871093] fsl_proxy: FSL DPAA Proxy initialization driver
[ 2.876895] fsl_oh: FSL FMan Offline Parsing port driver
[ 2.883181] hclge is initializing
[ 2.886503] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 2.893719] hns3: Copyright (c) 2017 Huawei Corporation.
[ 2.899058] e1000: Intel(R) PRO/1000 Network Driver
[ 2.903932] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 2.909787] e1000e: Intel(R) PRO/1000 Network Driver
[ 2.914752] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 2.920699] igb: Intel(R) Gigabit Ethernet Network Driver
[ 2.926092] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 2.931685] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 2.937945] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 2.944288] sky2: driver version 1.30
[ 2.949453] usbcore: registered new interface driver r8152
[ 2.954955] usbcore: registered new interface driver asix
[ 2.960367] usbcore: registered new interface driver ax88179_178a
[ 2.966865] VFIO - User Level meta-driver version: 0.3
[ 2.975727] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 2.982261] ehci-pci: EHCI PCI platform driver
[ 2.986723] ehci-platform: EHCI generic platform driver
[ 2.992118] ehci-orion: EHCI orion driver
[ 2.996250] ehci-exynos: EHCI Exynos driver
[ 3.000529] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 3.006710] ohci-pci: OHCI PCI platform driver
[ 3.011172] ohci-platform: OHCI generic platform driver
[ 3.016542] ohci-exynos: OHCI Exynos driver
[ 3.021327] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.026820] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 3.034541] xhci-hcd xhci-hcd.0.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
[ 3.043958] xhci-hcd xhci-hcd.0.auto: irq 55, io mem 0x02f00000
[ 3.050343] hub 1-0:1.0: USB hub found
[ 3.054105] hub 1-0:1.0: 1 port detected
[ 3.058208] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 3.063695] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 3.071353] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[ 3.078175] hub 2-0:1.0: USB hub found
[ 3.081936] hub 2-0:1.0: 1 port detected
[ 3.086100] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 3.091592] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 3
[ 3.099302] xhci-hcd xhci-hcd.1.auto: hcc params 0x0220f66d hci version 0x100 quirks 0x0000000002010810
[ 3.108711] xhci-hcd xhci-hcd.1.auto: irq 56, io mem 0x03000000
[ 3.114995] hub 3-0:1.0: USB hub found
[ 3.118754] hub 3-0:1.0: 1 port detected
[ 3.122835] xhci-hcd xhci-hcd.1.auto: xHCI Host Controller
[ 3.128320] xhci-hcd xhci-hcd.1.auto: new USB bus registered, assigned bus number 4
[ 3.135975] xhci-hcd xhci-hcd.1.auto: Host supports USB 3.0 SuperSpeed
[ 3.141521] random: fast init done
[ 3.142791] hub 4-0:1.0: USB hub found
[ 3.149642] hub 4-0:1.0: 1 port detected
[ 3.154126] usbcore: registered new interface driver uas
[ 3.159490] usbcore: registered new interface driver usb-storage
[ 3.169214] ftm-alarm 29d0000.timer: registered as rtc1
[ 3.175634] i2c /dev entries driver
[ 3.182291] ptp_qoriq: device tree node missing required elements, try automatic configuration
[ 3.191002] pps pps0: new PPS source ptp0
[ 3.223698] qoriq-cpufreq qoriq-cpufreq: Freescale QorIQ CPU frequency scaling driver
[ 3.232583] sdhci: Secure Digital Host Controller Interface driver
[ 3.238769] sdhci: Copyright(c) Pierre Ossman
[ 3.243830] Synopsys Designware Multimedia Card Interface Driver
[ 3.251244] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.259485] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.266882] usbcore: registered new interface driver usbhid
[ 3.272458] usbhid: USB HID core driver
[ 3.277879] Freescale USDPAA process driver
[ 3.282065] fsl-usdpaa: no region found
[ 3.283988] mmc0: SDHCI controller on 1560000.esdhc [1560000.esdhc] using ADMA 64-bit
[ 3.285898] Freescale USDPAA process IRQ driver
[ 3.303210] optee: probing for conduit method.
[ 3.307667] optee: api uid mismatch
[ 3.311158] optee: probe of firmware:optee failed with error -22
[ 3.324825] NET: Registered protocol family 26
[ 3.329313] u32 classifier
[ 3.332050] input device check on
[ 3.335701] Actions configured
[ 3.339529] Initializing XFRM netlink socket
[ 3.343856] NET: Registered protocol family 10
[ 3.348991] Segment Routing with IPv6
[ 3.352709] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 3.358945] NET: Registered protocol family 17
[ 3.363397] NET: Registered protocol family 15
[ 3.367874] Bridge firewalling registered
[ 3.372022] 8021q: 802.1Q VLAN Support v1.8
[ 3.376222] lib80211: common routines for IEEE802.11 drivers
[ 3.381918] 9pnet: Installing 9P2000 support
[ 3.386220] tsn generic netlink module v1 init...
[ 3.390966] Key type dns_resolver registered
[ 3.395529] registered taskstats version 1
[ 3.399630] Loading compiled-in X.509 certificates
[ 3.405397] Btrfs loaded, crc32c=crc32c-generic
[ 3.412851] ALSA device list:
[ 3.415814] No soundcards found.
[ 3.419459] Waiting for root device PARTUUID=b5fc3971-04...
[ 3.511024] random: crng init done
[ 17.467953] xhci-hcd xhci-hcd.1.auto: Error while assigning device slot ID
[ 17.474858] xhci-hcd xhci-hcd.1.auto: Max number of devices this xHCI host supports is 127.
[ 17.483247] usb usb4-port1: couldn't allocate usb_device
Note: I tried USB1 aswell, but this usb port doesn't recognize the USB stick at all.
U-Boot 2017.07-g503eff0 (Sep 26 2017 - 15:00:50 +0800)
SoC:  LS1043AE Rev1.1 (0x87920011)
Clock Configuration:
       CPU0(A53):1600 MHz  CPU1(A53):1600 MHz  CPU2(A53):1600 MHz
       CPU3(A53):1600 MHz
       Bus:      400  MHz  DDR:      1600 MT/s  FMAN:     500  MHz
Reset Configuration Word (RCW):
       00000000: 08100010 0a000000 00000000 00000000
       00000010: 14550002 80004012 e0025000 c1002000
       00000020: 00000000 00000000 00000000 00038800
       00000030: 00000000 00001101 00000096 00000001
Model: LS1043A RDB Board
CPLD:  V2.0
PCBA:  V6.0
SERDES Reference Clocks:
SD1_CLK1 = 156.25MHZ, SD1_CLK2 = 100.00MHZ
I2C:   ready
DRAM:  Initializing DDR....
Detected UDIMM Fixed DDR on board
1.9 GiB (DDR4, 32-bit, CL=11, ECC off)
Using SERDES1 Protocol: 5205 (0x1455)
SEC0: RNG instantiated
PPA Firmware: Version LSDK-17.09
Firmware 'Microcode version 0.0.1 for LS1021a r1.0' for 1021 V1.0
QE: uploading microcode 'Microcode for LS1021a r1.0' version 0.0.1
Flash: 128 MiB
NAND:  512 MiB
MMC:   FSL_SDHC: 0
EEPROM: NXID v1
In:    serial
Out:   serial
Err:   serial
Net:   Fman1: Uploading microcode version 108.4.9
PCIe0: pcie@3400000 disabled
PCIe1: pcie@3500000 Root Complex: no link
PCIe2: pcie@3600000 Root Complex: no link
FM1@DTSEC1, FM1@DTSEC2, FM1@DTSEC3 [PRIME], FM1@DTSEC4, FM1@DTSEC5, FM1@DTSEC6, FM1@TGEC1
Hit any key to stop autoboot:  0
=> run bootcmd_usb0
starting USB...
USB0:   Register 200017f NbrPorts 2
Starting the controller
USB XHCI 1.00
USB1:   Register 200017f NbrPorts 2
USB XHCI 1.00
USB2:   Register 200017f NbrPorts 2
USB XHCI 1.00
scanning bus 0 for devices... 1 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
Any suggestions?
