LS1043 USB1-3.0can not detect
2,639 次查看
allan_yi
please ref the attachment which is the schematic of usb. we found the usb1 port only detect USB2.0,can not detect usb3.0.
the usb3.0 terminal can work on other usb3.0 host.
2,576 次查看
Pavel
Check the values of the USBx_GHWPARAMS3 and USBx_DCFG registers.
The LS1046a USB register after reset are configured for SuperSpeed mode.
Pavel Chubakov
2,576 次查看
Pavel
Check your board using attached files. These files contains documentation and schematic for the LS1043ARDB USB and layout guidelines for high-speed interfaces (USB, PCI).
Pavel Chubakov
2,576 次查看
allan_yi
we had checked the schematic and compare with the reference design of LS1043RDB,however,we did not found any problem.
whether do some configs abou software or not? such as rcw or Register
