LS1028ARDB I2C eeprom: how to load the RCW and the bootloaders
5,676 次查看
imuguruza
Hi, I would like to know how can I load in the I2C eeprom the RCW and the BLs in order to boot the board from this source.
I have found this thread: https://community.nxp.com/t5/QorIQ/LS1028-RCW-generation-to-boot-from-I2C-EEPROM-to-NOR-Flash/m-p/14..., but I got stucked too.
I would like to know which version of the BL2 I need to load, bl2_emmc, bl2_sd,... but in my Yocto compilation bl2_i2c does not appear.
Do I need to change something in order to generate this? Or it is not necessary?
imuguruza
9 回复数
4,887 次查看
imuguruza
Hi again,
It has been time since I have tried this but it does not work.
I have been checking the I2C signals in the connector J26. When I boot up the board, I only see one I2C command. This command is a write request to the 0x50 address. It has no ACK from the EEPROM:
This means the I2C multiplexor is not well configured and it is not connecting to its bus 0, where the EEPROM is attached...
I believe the CPLD should configure this device in order to enable the path from the LS to the EEPROM.
Is there any workaround to make it work? Is this a known issue?
imuguruza
5,633 次查看
imuguruza
Thanks for your support.
It looks like when I execute:
=> i2c write 0xa0000000 0x50 0x400.2 0x13431
The processor gets hung up, so I am not sure if the bl2 binary is properly flahsed in the eeprom...
I have written the size in hex format in the i2c write command. Once it looks it has finished, I have changed the boot switch but nothing was printed in the serial session...
I have another question, is it required to reflash the fip? In my case, I would liketo use the nand as place to store the uboot/kernel/rtfs.
imuguruza
5,567 次查看
yipingwang
Please try images in i2c_ls1028a.zip attached in https://community.nxp.com/t5/QorIQ/LS1028-RCW-generation-to-boot-from-I2C-EEPROM-to-NOR-Flash/m-p/14...
=> tftp 0xa0000000 rcw_1500_gpu600.bin
=> i2c write 0xa0000000 0x50 0.2 10c
=> tftp 0xa0000000 bl2.bin
=> i2c write 0xa0000000 0x50 0x400.2 9431
Please flash fip image at 0x100000 on the NAND flash.
5,500 次查看
imuguruza
Hi @yipingwang
In the process of writing the bl2.bin, the board get freezed, and I believe that is not being loaded properly...
Here a capture:
Checkig the LS1028ARDB schematics, I think the pin sw_cfg_wp should be to '0' to allow eeprom writing:
I have set that too, but the writing process freezes and after, once I change to boot option to eeprom, I don't see any printed character.
Any idea what could be wrong?
imuguruza
5,336 次查看
yipingwang
Please check whether you could write RCW image to i2c eeprom.
=> tftp 0xa0000000 nxa22585/ls1028ardb/rcw_1500_gpu600.bin
=> i2c write 0xa0000000 0x50 0.2 0x10c
=>reset
=> i2c read 0x50 0.2 0x10c 0xc0000000
=> md 0xc0000000
c0000000: aa55aa55 80100000 3c004010 00000030 U.U......@.<0...
c0000010: 00000000 00000000 00000000 018f0000 ................
c0000020: 0030c000 00000000 020031a0 00002580 ..0......1...%..
c0000030: 00000000 00003296 00000000 00000010 .....2..........
c0000040: 00000000 00000000 00000000 00000000 ................
c0000050: 00000000 00000000 00000000 00000000 ................
c0000060: 00000000 00000000 00000000 00000000 ................
c0000070: 200e705a 00000000 bb580000 00000000 Zp. ......X.....
c0000080: 00000000 00000000 458ca4b5 334008bc ...........E..@3
c0000090: 00000001 33400154 47474747 33400158 ....T.@3GGGGX.@3
c00000a0: 47474747 334008bc 00000000 335008bc GGGG..@3......P3
c00000b0: 00000001 33500154 47474747 335008bc ....T.P3GGGG..P3
c00000c0: 00000000 33400890 00800401 33500890 ......@3......P3
c00000d0: 00800401 33400098 00000000 33500098 ......@3......P3
c00000e0: 00000000 31e00900 00000004 31e00400 .......1.......1
c00000f0: 1800d000 8000000a 00000400 1800d000 ................
5,430 次查看
imuguruza
ping @yipingwang
5,612 次查看
imuguruza
ping @yipingwang , any idea what's going on?
imuguruza
5,652 次查看
yipingwang
Here are the updated steps:
$ bitbake rcw -c cleansstate
$ bitbake rcw -c patch
Go to RCW source code folder, build_ls1028ardb/tmp/work/ls1028ardb-fsl-linux/rcw/git-r0/git/ls1028ardb/R_SQPP_0x85bb/, add the following commands at the end in rcw_1500_gpu600.rcw file
.pbi
write 0x01e00400,0x1800d000
blockcopy 0xa,0x400,0x1800d000,0x9435
.end
CCSR write command:
setting boot location pointer to 0x1800d000 in Boot location pointer low-order address (BOOTLOCPTRL) register present in DCFG.
block copy command:
blockcopy 0x0a,0x400,0x00100000,0x9400
Source : I2C EEPROM = 0xa
Source address: 0x400
Destination address: OCRAM (0x100000)
Block size : size of BL2 binary in bytes
$ bitbak rcw
$ bitbake atf -c cleansstate
$ bitbake atf
Get atf images bl2_flexspi_nor.pbl and fip_uboot.bin in build_ls1028ardb/tmp/deploy/images/ls1028ardb/atf/.
Programming EEPROM using I2C on U-Boot on LS1028ARDB
=> i2c probe
Valid chip addresses: 00 50 52 53 57 66 67 77 7C
=> i2c write 0xa0000000 0x50 0.2 0x11c
=> i2c read 0x50 0.2 0x114 0xc0000000
=> i2c write 0xa0000000 0x50 0x400.2 <size of bl2.bin>
1,272 次查看
gjohnsona2e
I know this is an old thread, but I am having a similar problem to this ticket.  I followed the steps to program the rcw and bl2 bins to eeprom using u-boot from a bootable SD card, and verified the data is present in the EEPROM.  When I reconfigure the switches to boot from EEPROM, and capture the i2c traffic on j26 i see:
It appears that the EEPROM is not responding.
Can you help me figure out how to make this work as it's claimed to work?
标记 (4)
%3CLINGO-SUB%20id%3D%22lingo-sub-1516012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3ELS1028ARDB%20I2C%20eeprom%EF%BC%9A%E5%A6%82%E4%BD%95%E5%8A%A0%E8%BD%BD%20RCW%20%E5%92%8C%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E7%A8%8B%E5%BA%8F%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1516012%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%EF%BC%8C%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E5%A6%82%E4%BD%95%E5%9C%A8%20I2C%20eeprom%20%E4%B8%AD%E5%8A%A0%E8%BD%BD%20RCW%20%E5%92%8C%20BL%EF%BC%8C%E4%BB%A5%E4%BE%BF%E4%BB%8E%E8%BF%99%E4%B8%AA%E6%BA%90%E5%A4%B4%E5%90%AF%E5%8A%A8%E4%B8%BB%E6%9D%BF%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%BE%E5%88%B0%E4%BA%86%E8%BF%99%E4%B8%AA%E4%B8%BB%E9%A2%98%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FQorIQ%2FLS1028-RCW-generation-to-boot-from-I2C-EEPROM-to-NOR-Flash%2Fm-p%2F1455702%22%20target%3D%22_blank%22%3E%EF%BC%9Ahttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FQorIQ%2FLS1028-RCW-generation-to-boot-from-I2C-EEPROM-to-NOR-Flash%2Fm-p%2F1455702%E3%80%81%3C%2FA%3E%E4%BD%86%E6%88%91%E4%B9%9F%E8%A2%AB%E5%8D%A1%E4%BD%8F%E4%BA%86%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E7%9F%A5%E9%81%93%E9%9C%80%E8%A6%81%E5%8A%A0%E8%BD%BD%E5%93%AA%E4%B8%AA%E7%89%88%E6%9C%AC%E7%9A%84%20BL2%EF%BC%8Cbl2_emmc%E3%80%81bl2_sd......%E4%BD%86%E5%9C%A8%E6%88%91%E7%9A%84%20Yocto%20%E7%BC%96%E8%AF%91%E4%B8%AD%EF%BC%8C%E5%B9%B6%E6%B2%A1%E6%9C%89%E5%87%BA%E7%8E%B0%20bl2_i2c%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E9%9C%80%E8%A6%81%E4%BF%AE%E6%94%B9%E4%BB%80%E4%B9%88%E6%89%8D%E8%83%BD%E7%94%9F%E6%88%90%E8%BF%99%E4%B8%AA%E5%90%97%EF%BC%9F%E8%BF%98%E6%98%AF%E6%B2%A1%E6%9C%89%E5%BF%85%E8%A6%81%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E4%BC%8A%E7%A9%86%E5%8F%A4%E9%B2%81%E6%89%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2150320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028ARDB%20I2C%20eeprom%3A%20how%20to%20load%20the%20RCW%20and%20the%20bootloaders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2150320%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E7%9F%A5%E9%81%93%E8%BF%99%E6%98%AF%E4%B8%AA%E8%80%81%E8%AF%9D%E9%A2%98%EF%BC%8C%E4%BD%86%E6%88%91%E9%81%87%E5%88%B0%E7%9A%84%E9%97%AE%E9%A2%98%E4%B8%8E%E8%BF%99%E5%BC%A0%E7%A5%A8%E7%B1%BB%E4%BC%BC%E3%80%82%20%E6%88%91%E6%8C%89%E7%85%A7%E6%AD%A5%E9%AA%A4%E4%BD%BF%E7%94%A8%E5%8F%AF%E5%90%AF%E5%8A%A8%E7%9A%84%20SD%20%E5%8D%A1%E4%B8%AD%E7%9A%84%20u-boot%20%E5%B0%86%20rcw%20%E5%92%8C%20bl2%20%E5%9E%83%E5%9C%BE%E7%AE%B1%E7%BC%96%E7%A8%8B%E5%88%B0%20eeprom%20%E4%B8%AD%EF%BC%8C%E5%B9%B6%E9%AA%8C%E8%AF%81%E4%BA%86%E6%95%B0%E6%8D%AE%E5%AD%98%E5%9C%A8%E4%BA%8E%20EEPROM%20%E4%B8%AD%E3%80%82%E5%BD%93%E6%88%91%E5%B0%86%E4%BA%A4%E6%8D%A2%E6%9C%BA%E9%87%8D%E6%96%B0%E9%85%8D%E7%BD%AE%E4%B8%BA%E4%BB%8E%20EEPROM%20%E5%90%AF%E5%8A%A8%E5%B9%B6%E6%8D%95%E8%8E%B7%20j26%20%E4%B8%8A%E7%9A%84%20i2c%20%E6%B5%81%E9%87%8F%E6%97%B6%EF%BC%8C%E6%88%91%E7%9C%8B%E5%88%B0%E4%BA%86%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22gjohnsona2e_0-1754945606921.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22gjohnsona2e_0-1754945606921.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F351851iABD9E60BCA151A9E%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22gjohnsona2e_0-1754945606921.png%22%20alt%3D%22gjohnsona2e_0-1754945606921.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E7%9C%8B%E6%9D%A5%20EEPROM%20%E6%B2%A1%E6%9C%89%E5%93%8D%E5%BA%94%E3%80%82%3C%2FP%3E%3CP%3E%E6%82%A8%E8%83%BD%E5%B8%AE%E6%88%91%E5%BC%84%E6%98%8E%E7%99%BD%E5%A6%82%E4%BD%95%E8%AE%A9%E5%AE%83%E5%83%8F%E5%AE%A3%E7%A7%B0%E7%9A%84%E9%82%A3%E6%A0%B7%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1635330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028ARDB%20I2C%20eeprom%3A%20how%20to%20load%20the%20RCW%20and%20the%20bootloaders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1635330%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%8F%88%E8%A7%81%E9%9D%A2%E4%BA%86%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%BE%88%E4%B9%85%E6%B2%A1%E6%9C%89%E8%AF%95%E8%BF%87%E8%BF%99%E4%B8%AA%E4%BA%86%EF%BC%8C%E4%BD%86%E5%AE%83%E4%B8%8D%E8%B5%B7%E4%BD%9C%E7%94%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E4%B8%80%E7%9B%B4%E5%9C%A8%E6%A3%80%E6%9F%A5%E8%BF%9E%E6%8E%A5%E5%99%A8%20J26%20%E4%B8%8A%E7%9A%84%20I2C%20%E4%BF%A1%E5%8F%B7%E3%80%82%E5%BD%93%E6%88%91%E5%90%AF%E5%8A%A8%E6%9D%BF%E6%97%B6%EF%BC%8C%E6%88%91%E5%8F%AA%E7%9C%8B%E5%88%B0%E4%B8%80%E4%B8%AA%20I2C%20%E5%91%BD%E4%BB%A4%E3%80%82%E8%AF%A5%E5%91%BD%E4%BB%A4%E6%98%AF%E5%AF%B9%200x50%20%E5%9C%B0%E5%9D%80%E7%9A%84%E5%86%99%E5%85%A5%E8%AF%B7%E6%B1%82%E3%80%82%E5%AE%83%E6%B2%A1%E6%9C%89%E6%9D%A5%E8%87%AA%20EEPROM%20%E7%9A%84%20ACK%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22i2c_eeprom.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22i2c_eeprom.png%22%20style%3D%22width%3A%20400px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F219624i7FBAE3AE1132842C%2Fimage-size%2Fmedium%3Fv%3Dv2%26amp%3Bpx%3D400%22%20role%3D%22button%22%20title%3D%22i2c_eeprom.png%22%20alt%3D%22i2c_eeprom.png%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%BF%99%E6%84%8F%E5%91%B3%E7%9D%80%20I2C%20%E5%A4%9A%E8%B7%AF%E5%A4%8D%E7%94%A8%E5%99%A8%E7%9A%84%E9%85%8D%E7%BD%AE%E4%B8%8D%E6%AD%A3%E7%A1%AE%EF%BC%8C%E5%AE%83%E6%B2%A1%E6%9C%89%E8%BF%9E%E6%8E%A5%E5%88%B0%E8%BF%9E%E6%8E%A5%20EEPROM%20%E7%9A%84%E6%80%BB%E7%BA%BF%200...%3C%2FP%3E%3CP%3E%E6%88%91%E7%9B%B8%E4%BF%A1%20CPLD%20%E5%BA%94%E8%AF%A5%E9%85%8D%E7%BD%AE%E8%BF%99%E4%B8%AA%E8%AE%BE%E5%A4%87%E4%BB%A5%E5%90%AF%E7%94%A8%E4%BB%8E%20LS%20%E5%88%B0%20EEPROM%20%E7%9A%84%E8%B7%AF%E5%BE%84%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%9C%89%E4%BB%80%E4%B9%88%E5%8F%98%E9%80%9A%E5%8A%9E%E6%B3%95%E5%8F%AF%E4%BB%A5%E8%AE%A9%E5%AE%83%E6%AD%A3%E5%B8%B8%E5%B7%A5%E4%BD%9C%E5%90%97%EF%BC%9F%E8%BF%99%E6%98%AF%E4%B8%80%E4%B8%AA%E5%B7%B2%E7%9F%A5%E7%9A%84%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E4%BC%8A%E7%A9%86%E5%8F%A4%E9%B2%81%E6%89%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1534667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028ARDB%20I2C%20eeprom%3A%20how%20to%20load%20the%20RCW%20and%20the%20bootloaders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1534667%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E6%A3%80%E6%9F%A5%E8%83%BD%E5%90%A6%E5%B0%86%20RCW%20%E6%98%A0%E5%83%8F%E5%86%99%E5%85%A5%20i2c%20eeprom%E3%80%82%3C%2FP%3E%0A%3CP%3E%3D%26gt%3B%20tftp%200xa0000000%20nxa22585%2Fls1028ardb%2Frcw_1500_gpu600.bin%3CBR%20%2F%3E%3D%26gt%3B%20i2c%20%E5%86%99%200xa0000000%200x50%200.2%200x10c%3C%2FP%3E%0A%3CP%3E%3D%20%26gt%3B%20%E9%87%8D%E7%BD%AE%3C%2FP%3E%0A%3CP%3E%3D%26gt%3B%20i2c%20read%200x50%200.2%200x10c%200xc0000000%3CBR%20%2F%3E%3D%26gt%3B%20md%200xc0000000%3CBR%20%2F%3Ec0000000%3A%20aa55aa55%2080100000%203c004010%2000000030%20U.U......%40.%26lt%3B0...%3CBR%20%2F%3Ec0000010%EF%BC%9A00000000%2000000000%2000000000%20018f0000%20................%3CBR%20%2F%3Ec0000020%3A%200030c000%2000000000%20020031a0%2000002580%20...0......1...%25...%3CBR%20%2F%3Ec0000030%3A%2000000000%2000003296%2000000000%2000000010%20.....2..........%3CBR%20%2F%3Ec0000040%3A%2000000000%2000000000%2000000000%20................%3CBR%20%2F%3Ec0000050%3A%2000000000%2000000000%2000000000%20................%3CBR%20%2F%3Ec0000060%3A%2000000000%2000000000%2000000000%20................%3CBR%20%2F%3Ec0000070%3A%20200e705a%2000000000%20bb580000%2000000000%20Zp.......X.....%3CBR%20%2F%3Ec0000080%3A%2000000000%2000000000%20458ca4b5%20334008bc%20...........E..%403%3CBR%20%2F%3Ec0000090%3A%2000000001%2033400154%2047474747%2033400158%20....T.%403GGGGX.%403%3CBR%20%2F%3Ec00000a0%3A%2047474747%20334008bc%2000000000%20335008bc%20GGGG..%403......P3%3CBR%20%2F%3Ec00000b0%3A%2000000001%2033500154%2047474747%20335008bc%20....T.P3GGGG..P3%3CBR%20%2F%3Ec00000c0%3A%2000000000%2033400890%2000800401%2033500890%20......%403......P3%3CBR%20%2F%3Ec00000d0%3A%2000800401%2033400098%2000000000%2033500098%20......%403......P3%3CBR%20%2F%3Ec00000e0%3A%2000000000%2031e00900%2000000004%2031e00400%20.......1.......1%3CBR%20%2F%3Ec00000f0%3A%201800d000%208000000a%2000000400%201800d000%20................%3CBR%20%2F%3E%3D%26gt%3B%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1531534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028ARDB%20I2C%20eeprom%3A%20how%20to%20load%20the%20RCW%20and%20the%20bootloaders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1531534%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3Eping%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1527944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028ARDB%20I2C%20eeprom%3A%20how%20to%20load%20the%20RCW%20and%20the%20bootloaders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1527944%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E5%9C%A8%E7%BC%96%E5%86%99%20bl2.bin%20%E7%9A%84%E8%BF%87%E7%A8%8B%E4%B8%AD%EF%BC%8C%E6%9D%BF%E8%A2%AB%E5%86%BB%E7%BB%93%E4%BA%86%EF%BC%8C%E6%88%91%E7%9B%B8%E4%BF%A1%E5%8A%A0%E8%BD%BD%E4%B8%8D%E6%AD%A3%E7%A1%AE...%3CBR%20%2F%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%8D%95%E8%8E%B7%EF%BC%9A%3C%2FP%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22error.PNG%22%20style%3D%22width%3A%20573px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22error.PNG%22%20style%3D%22width%3A%20573px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F194880i41964D29FBB578BF%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22error.PNG%22%20alt%3D%22error.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%9F%A5%E7%9C%8B%20LS1028ARDB%20%E5%8E%9F%E7%90%86%E5%9B%BE%EF%BC%8C%E6%88%91%E8%AE%A4%E4%B8%BA%20sw_cfg_wp%20%E5%BC%95%E8%84%9A%E5%BA%94%E4%B8%BA%20%220%22%EF%BC%8C%E4%BB%A5%E5%85%81%E8%AE%B8%E5%86%99%E5%85%A5%20eeprom%EF%BC%9A%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%3CSPAN%20class%3D%22lia-inline-image-display-wrapper%20lia-image-align-inline%22%20image-alt%3D%22switch.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cspan%20class%3D%22lia-inline-image-display-wrapper%22%20image-alt%3D%22switch.PNG%22%20style%3D%22width%3A%20999px%3B%22%3E%3Cimg%20src%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fimage%2Fserverpage%2Fimage-id%2F194881iE810F16580F72020%2Fimage-size%2Flarge%3Fv%3Dv2%26amp%3Bpx%3D999%22%20role%3D%22button%22%20title%3D%22switch.PNG%22%20alt%3D%22switch.PNG%22%20%2F%3E%3C%2Fspan%3E%3C%2FSPAN%3E%3C%2FP%3E%3CP%3E%E6%88%91%E4%B9%9F%E8%AE%BE%E7%BD%AE%E4%BA%86%EF%BC%8C%E4%BD%86%E6%98%AF%E5%86%99%E5%85%A5%E8%BF%87%E7%A8%8B%E5%86%BB%E7%BB%93%E4%BA%86%EF%BC%8C%E4%B9%8B%E5%90%8E%EF%BC%8C%E4%B8%80%E6%97%A6%E6%88%91%E5%88%87%E6%8D%A2%E5%88%B0eeprom%E7%9A%84%E5%90%AF%E5%8A%A8%E9%80%89%E9%A1%B9%EF%BC%8C%E6%88%91%E5%B0%B1%E7%9C%8B%E4%B8%8D%E5%88%B0%E4%BB%BB%E4%BD%95%E6%89%93%E5%8D%B0%E7%9A%84%E5%AD%97%E7%AC%A6%E3%80%82%3C%2FP%3E%3CP%3E%E7%9F%A5%E9%81%93%E5%8F%AF%E8%83%BD%E5%87%BA%E4%BA%86%E4%BB%80%E4%B9%88%E9%97%AE%E9%A2%98%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BC%8A%E7%A9%86%E5%8F%A4%E9%B2%81%E6%89%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1524138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028ARDB%20I2C%20eeprom%3A%20how%20to%20load%20the%20RCW%20and%20the%20bootloaders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1524138%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%AF%B7%E5%B0%9D%E8%AF%95%3CSPAN%3E%20%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2FQorIQ%2FLS1028-RCW-generation-to-boot-from-I2C-EEPROM-to-NOR-Flash%2Fm-p%2F1455702%22%20target%3D%22_blank%22%3Ehttps%3A%2F%2Fcommunity.nxp.com%2Ft5%2FQorIQ%2FLS1028-RCW-generation-to-boot-from-I2C-EEPROM-to-NOR-Flash%2Fm-p%2F1455702%3C%2FA%3E%E4%B8%AD%E6%89%80%E9%99%84%20i2c_ls1028a.zip%20%E4%B8%AD%3C%2FSPAN%3E%E7%9A%84%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3D%26gt%3B%20tftp%200xa0000000%20rcw_1500_gpu600.bin%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3D%26gt%3B%20i2c%20%E5%86%99%200xa0000000%200x50%200.2%2010c%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3D%26gt%3B%20tftp%200xa0000000%20bl2.bin%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%3CSPAN%3E%3D%26gt%3B%20i2c%20%E5%86%99%200xa0000000%200x50%200x400.29431%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%9C%A8%E4%B8%8E%E9%9D%9E%E9%97%AA%E5%AD%98%E5%99%A8%E4%B8%8A%E4%BB%A5%200x100000%20%E7%9A%84%E9%80%9F%E5%BA%A6%E9%97%AA%E7%83%81%20fip%20%E5%9B%BE%E5%83%8F%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1522646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028ARDB%20I2C%20eeprom%3A%20how%20to%20load%20the%20RCW%20and%20the%20bootloaders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1522646%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E5%B9%B3%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F52411%22%20target%3D%22_blank%22%3E%40yipingwang%3C%2FA%3E%EF%BC%8C%E7%9F%A5%E9%81%93%E5%8F%91%E7%94%9F%E4%BA%86%E4%BB%80%E4%B9%88%E5%90%97%EF%BC%9F%3C%2FP%3E%3CP%3E%E6%AD%A4%E8%87%B4%EF%BC%8C%3C%2FP%3E%3CP%3E%E4%BC%8A%E7%A9%86%E5%8F%A4%E9%B2%81%E6%89%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1520420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028ARDB%20I2C%20eeprom%3A%20how%20to%20load%20the%20RCW%20and%20the%20bootloaders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1520420%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%E4%BD%A0%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FP%3E%3CP%3E%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%B0%B1%E5%83%8F%E6%88%91%E6%89%A7%E8%A1%8C%E6%97%B6%E7%9A%84%E6%A0%B7%E5%AD%90%EF%BC%9A%3C%2FP%3E%3CP%3E%3D%26gt%3B%20i2c%20%E5%86%99%200xa0000000%200x50%200x400.20x13431%3C%2FP%3E%3CP%3E%E5%A4%84%E7%90%86%E5%99%A8%E6%8C%82%E6%9C%BA%E4%BA%86%EF%BC%8C%E6%89%80%E4%BB%A5%E6%88%91%E4%B8%8D%E7%A1%AE%E5%AE%9A%20eeprom%20%E4%B8%AD%E6%98%AF%E5%90%A6%E6%AD%A3%E7%A1%AE%E5%88%B7%E6%96%B0%E4%BA%86%20bl2%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6...%3C%2FP%3E%3CP%3E%E6%88%91%E5%B7%B2%E7%BB%8F%E5%9C%A8i2c%E5%86%99%E5%85%A5%E5%91%BD%E4%BB%A4%E4%B8%AD%E4%BB%A5%E5%8D%81%E5%85%AD%E8%BF%9B%E5%88%B6%E6%A0%BC%E5%BC%8F%E5%86%99%E4%BA%86%E5%A4%A7%E5%B0%8F%E3%80%82%E7%9C%8B%E8%B5%B7%E6%9D%A5%E5%B7%B2%E7%BB%8F%E5%AE%8C%E6%88%90%E4%BA%86%EF%BC%8C%E6%88%91%E5%B7%B2%E7%BB%8F%E6%9B%B4%E6%8D%A2%E4%BA%86%E5%90%AF%E5%8A%A8%E5%BC%80%E5%85%B3%EF%BC%8C%E4%BD%86%E5%9C%A8%E4%B8%B2%E8%A1%8C%E4%BC%9A%E8%AF%9D%E4%B8%AD%E4%BB%80%E4%B9%88%E4%B9%9F%E6%B2%A1%E6%89%93%E5%8D%B0...%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E6%88%91%E8%BF%98%E6%9C%89%E4%B8%80%E4%B8%AA%E9%97%AE%E9%A2%98%EF%BC%8C%E6%98%AF%E5%90%A6%E9%9C%80%E8%A6%81%E9%87%8D%E6%96%B0%E5%88%B7%E6%96%B0%20fip%EF%BC%9F%E5%B0%B1%E6%88%91%E8%80%8C%E8%A8%80%EF%BC%8C%E6%88%91%E6%83%B3%E7%94%A8%E4%B8%8E%E9%9D%9E%E4%BD%9C%E4%B8%BA%E5%AD%98%E5%82%A8%20uboot%2Fkernel%2Frtfs%20%E7%9A%84%E5%9C%B0%E6%96%B9%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E4%BC%8A%E7%A9%86%E5%8F%A4%E9%B2%81%E6%89%8E%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-1519741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20LS1028ARDB%20I2C%20eeprom%3A%20how%20to%20load%20the%20RCW%20and%20the%20bootloaders%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-1519741%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%3CSPAN%3E%E4%BB%A5%E4%B8%8B%E6%98%AF%E6%9B%B4%E6%96%B0%E5%90%8E%E7%9A%84%E6%AD%A5%E9%AA%A4%EF%BC%9A%3C%2FSPAN%3E%3C%2FP%3E%0A%3CP%3E%24%20bitbake%20rcw%20-c%20cleansstate%3C%2FP%3E%0A%3CP%3E%24%20bitbake%20rcw%20-c%20patch%3C%2FP%3E%0A%3CP%3E%E8%BF%9B%E5%85%A5%20RCW%20%E6%BA%90%E4%BB%A3%E7%A0%81%E6%96%87%E4%BB%B6%E5%A4%B9%20build_ls1028ardb%2Ftmp%2Fwork%2Fls1028ardb-fsl-linux%2Frcw%2Fgit-r0%2Fgit%2Fls1028ardb%2FR_SQPP_0x85bb%2F%EF%BC%8C%3CSPAN%3E%E5%9C%A8%20rcw_1500_gpu600.rcw%20%E6%96%87%E4%BB%B6%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E.pbi%3C%2FSPAN%3E%E7%9A%84%E6%9C%AB%E5%B0%BE%E6%B7%BB%E5%8A%A0%E4%BB%A5%E4%B8%8B%E5%91%BD%E4%BB%A4%3CBR%20%2F%3E%3CSPAN%3E%E5%86%99%200x01e00400%2C0x1800d000%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3Eblockcopy%200xa%2C0x400%2C0x1800d000%2C0x9435%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E.%E7%BB%93%E6%9D%9F%3C%2FSPAN%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3ECCSR%20%E5%86%99%E5%85%A5%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E5%9C%A8%20DCFG%20%E4%B8%AD%E5%AD%98%E5%9C%A8%E7%9A%84%20%E5%90%AF%E5%8A%A8%E4%BD%8D%E7%BD%AE%E6%8C%87%E9%92%88%E4%BD%8E%E9%98%B6%E5%9C%B0%E5%9D%80%20(BOOTLOCPTRL)%20%E5%AF%84%E5%AD%98%E5%99%A8%E4%B8%AD%E5%B0%86%E5%90%AF%E5%8A%A8%E4%BD%8D%E7%BD%AE%E6%8C%87%E9%92%88%20%E8%AE%BE%E7%BD%AE%E4%B8%BA%200x1800d000%20%E3%80%82%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E5%8C%BA%E5%9D%97%E5%A4%8D%E5%88%B6%E5%91%BD%E4%BB%A4%EF%BC%9A%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20blockcopy%200x0a%2C0x400%2C0x00100000%2C0x9400%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E6%9D%A5%E6%BA%90%EF%BC%9A%20I2C%20EEPROM%20%3D%200xa%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E6%BA%90%E5%9C%B0%E5%9D%80%EF%BC%9A0x400%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E7%9B%AE%E6%A0%87%E5%9C%B0%E5%9D%80%EF%BC%9AOCRAM%20(0x100000)%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E5%8C%BA%E5%9D%97%E5%A4%A7%E5%B0%8F%EF%BC%9AB%20L2%20%E4%BA%8C%E8%BF%9B%E5%88%B6%E6%96%87%E4%BB%B6%E7%9A%84%E5%A4%A7%E5%B0%8F%EF%BC%88%E4%BB%A5%E5%AD%97%E8%8A%82%E4%B8%BA%E5%8D%95%E4%BD%8D%EF%BC%89%3C%2FSPAN%3E%3C%2FP%3E%0A%3CBR%20%2F%3E%0A%3CP%3E%24%20bitbak%20rcw%3C%2FP%3E%0A%3CP%3E%24%20bitbake%20atf%20-c%20cleansstate%3C%2FP%3E%0A%3CP%3E%24%20bitbake%20atf%3C%2FP%3E%0A%3CP%3E%E8%8E%B7%E5%8F%96%20build_ls1028ardb%2Ftmp%2Fdeploy%2Fimages%2Fls1028ardb%2Fatf%2F%20%E4%B8%AD%E7%9A%84%20atf%20%E6%98%A0%E5%83%8F%20bl2_flexspi_nor.pbl%20%E5%92%8C%20fip_uboot.bin%E3%80%82%3CBR%20%2F%3E%3CBR%20%2F%3E%3CSPAN%3E%E5%9C%A8%20LS1028ARDB%20%E7%9A%84%20U-Boot%20%E5%90%AF%E5%8A%A8%E4%B8%8A%E4%BD%BF%E7%94%A8%20I2C%20%E7%BC%96%E7%A8%8B%20EEPROM%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%3D%20%26gt%3B%20i2c%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%E6%8E%A2%E6%B5%8B%E5%99%A8%20%E6%9C%89%E6%95%88%E8%8A%AF%E7%89%87%E5%9C%B0%E5%9D%80%EF%BC%9A00%2050%2052%2053%2057%2066%2067%2077%207C%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%3D%20%26gt%3B%20i2c%20%E5%86%99%E5%85%A5%200xa0000000%200x50%200.2%200x11c%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%3D%20%26gt%3B%20i2c%20%E8%AF%BB%E5%8F%96%200x50%200.2%200x114%200x114%200x0000000%3C%2FSPAN%3E%3CBR%20%2F%3E%3CSPAN%3E%20%3D%20%26gt%3B%20i2%20c%20%E5%86%99%E5%85%A5%200xa0000000%200x50%200x400.2%3CSIZE%20of%3D%22%22%20bl2.bin%3D%22%22%3E%3C%2FSIZE%3E%3C%2FSPAN%3E%3C%2FP%3E%3C%2FLINGO-BODY%3E
