Is there any other option to permanently save test application binary for execution on Board.
If you use a ramdisk-based root filesystem, which implies that all
changes are lost after a power cycle, you always have to re-build
and re-deploy the root FS image if you wish to see your changes after
a new power-on. Consider using an MTD-based root filesystem, JFFS2 or
UBIFS, if you want to keep your changes:
Platon
