Instructions of building Centos for QorIQ
hongcui
Hi, All,
I was wondering if there is instruction for building Centos for QorIQ?
https://community.nxp.com/docs/DOC-331215  did not contain any instruction.
Thanks!
Hong
yipingwang
Hello Hong,
Are you using Layerscape SDK? Please refer to https://www.nxp.com/docs/en/supporting-information/LSDK-KC-REV0.pdf, you could generate Ubuntu/CentOS/Debian based rootfs.
$ tar -xzvf flexbuild_lsdk1712_*.tgz
$ cd flexbuild
$ source setup.env
$ apt-get install git
$ flex-builder -i repo-fetch
$ flex-builder -i repo-tag
Modify configs/build_lsdk1712.cfg, change the "DISTROTYPE" to "centos" and "CODENAME" to "jessie".
$ flex-builder -i mkrfs -a arm64
rootfs image is deployed in build/images/centos_jessie_arm64_rootfs.d
The git hub address is as the following.
https://lsdk.github.io/
https://github.com/qoriq-open-source
Yiping
hongcui
Thanks a lot, Yiping.
Does it also support ppc64 architecture?
Sent from my iPhone
