How to generate DDR Address parity error?
mourad1996
I'm using 4GB DDR3 RAM with ECC chip are connected to T1040 Processor DDR controller.
I attempted this sequence, but it was unsuccessful to generate DDR Address parity error:
Step 1:
ERR_INT_EN[APEE] is set
DDR_SDRAM_CFG2[AP_EN] is set
Step 2:
DDR_ECC_ERR_INJECT[APIEN] = 1
Step 3:
Read the bit APE in DDR_ERR_DETECT
The read value of APE is zero.
Kindly suggest us, how to generate this error.
Thanks & Regards
yipingwang
The sequence seems to be correct. can you provide a log of this sequence that you have tried? I can review and try to duplicated it
