How to find the flavour of your kernel ?
已解决
跳至解决方案
1,475 次查看
sarathchandra
Hi all,
           I am using Yocto SDK1.4 for my QorIQ processor.
           When I am giving "uname -a" it is throwing like "Linux p1023 3.8.13-rt9-QorIQ-SDK-1.4 #3 SMP ${date} ppc GNU/LINUX".
           Here does the "QorIQ-SDK-1.4" is the flavour ?
           else kindly let me know.
Thanks & Regards,
Sarath
标记 (2)
1 解答
1,289 次查看
yipingwang
Hello Sarath,
The label "QorIQ-SDK-1.4" is Freescale Linux SDK flavour, actually in SDK it is called local version, you could find it is recorded in the file .scmversion in the Kernel source folder after configured by Yocto.
If you wan to modify this OS release version information, you could modify Kernel recipe, please edit the following code in Kernel recipe meta-fsl-ppc/recipes-kernel/linux/linux-qoriq-sdk.inc.
#add git revision to the local version
if [ "${SCMVERSION}" = "y" ]; then
       # append sdk version if SDK_VERSION is defined
       sdkversion=''
       if [ -n "${SDK_VERSION}" ]; then
           sdkversion="-${SDK_VERSION}"
       fi
       head=`git rev-parse --verify --short HEAD 2> /dev/null`
       printf "%s%s%s" $sdkversion +g $head > ${S}/.scmversion
fi
Yiping
在原帖中查看解决方案
2 回复数
1,289 次查看
sarathchandra
Thanks a lot Wang.
1,290 次查看
yipingwang
Hello Sarath,
       sdkversion=''
       fi
fi
Yiping
