How to change from rootfs to initramfs in lx2160ardb?
songhee_yun
@Yiping Wang
Now, I uses lx2160ardb reference board.
It consist of bootpartition image and rootfs image.
I want to change these images to initramfs image included bootpartition and rootfs.
How can i compile and booting for initramfs?
yipingwang
Hello songhee yun,
In bootpartition tar ball, you could find tiny itb image lsdk2004_yocto_tiny_LS_arm64.itb, which includes Kernel image, dtb file and ramdisk rootfs filesystem.
You could boot up the system with the following commands
=> load mmc 0:2 0xa0000000 lsdk2004_yocto_tiny_LS_arm64.itb
=>bootm 0xa0000000#lx2160ardb
Yiping
songhee_yun
Hi, Yiping~
I don't want to use tiny linux. I want to use my own kernel image and rootfs image.
Songhee
yipingwang
Hello Songhee,
You could consider to use Yocto 3.0 release from readme - qoriq-components/yocto-sdk - Repo manifest for QorIQ Yocto SDK
Using the following command Kernel image and ramdisk rootfs filesystem will be generated.
$./setup-env -m lx2160ardb
$ bitbake fsl-image-networking
Yiping
