How to build 32-bit by toolchain aarch64-fsl-linux
hawkinzhang
Hi,nxp
   i build toolchain : aarch64-fsl-linux from QorIQ-SDK-2.0  for LS1043A and install it. Now i found this is a 64-bit toolchain, If i want to build a 32-bit APP ,What should i do!
ryang
file:///Downloads/FTF-DES-N1850%20Porting%2032-bit%20Linux%20to%20ARM%C2%AEv8.pdf
Copy LS1021A’s configuration file to LS1043A’s source code −
$ cd < LS1043A-SDK-V0.4_Linux> −
$ cp < LS1021A-SDK-V1.3_Linux>/arc/arm/configs/ls1021a_defconfg .config
Porting 32-bit Linux to ARM®v8 | NXP
