How much flash memory is on the B4860QDS Eval board
Board has NAND NAND flash and parallel NOR flash
NAND flash - 512 Mbytes
Parallel NOR flash - 128M bytes
Currently the board boots and has a 30Mb root file system. So it must be booting from NOR flash. I want to switch to the NAND flash.
How does one tell Yocto SDK 1.8 to build a flash image for the NAND flash? I can select a dip switch to boot from NAND.
C-
