I using CodeWarrior 11.1 to flash my hex code to my PCB board. It give me the error below:
Error executing task KL16Z128M4
Error: Connect Failed.
Can't connect. The Debugger can not connect to the PE device(ARM GDI Protocol Adapter)
I tried different PE debugger (Multilink Universal FX and Tracelink) and several my PCB boards. I got the same error. I have a limit timing for my project.
NXP offers CW4NET for ARM based Layerscape processors:
This CodeWarrior uses CodeWarrior TAP debug tool.
Is there possibility to test your connection using CodeWarrior TAP?
Pavel Chubakov
