Burst Data Write from RAM to PCI Other Than DMA
1,408 次查看
mehmetcelik
Hi there,
We are using P2041 as the processor and we are looking for a way to make a burst transaction to PCI. Is there a way to make such transaction other than using DMA?
Thank you,
标签 (1)
1 回复
1,288 次查看
Bulat
I believe you ask if the core is able to burst to PCI. The core uses burst transactions to to fill/flush cache lines only. So you would need at least to set PCI memory area as cache-able.
Bulat
