After connectting LS1021ATSN-PA and wnidows7 with MIcro USB cable,my pc have not find serial ports
fengqingyang
Dear NPX Community,
I am learning to startup the LS1021ATSN-PA according the getting start guide.
1.connect the pc with LS1021ATSN-PA USB0 K22 port using the Mico USB Cable.
2.insert the Micro SDHC card from the kit contents.
3.I could not set up a serial terminal using teraterm——have not find the com ports in the PC,why?
thanks
ufedor
You need to install the USB drivers on the host computer before using the serial terminal.
You can download these drivers from:
https://mbed.org/handbook/Windows-serial-configuration
