1588 external trigger signal configure
2,724 次查看
zhujianbin
HI:
    Network topology:
          The master and slave can be synchronized using ptp4l.
          The Master's TESC_1588_PULSE_OUT1 and the Slave's TESC_1588_PULSE_OUT1 are aligned.
      My question is as follows:
          how to configure TESC_1588_PULSE_OUT1 and TESC_1588_TRIG_IN1(GPS's 1PPS input) are align in Master?
        Thanks a lot!
4 回复数
2,677 次查看
zhujianbin
hi yipingwang:
    Thank you for your reply.
     I can't find this document on this forum.
     Could you please send me a copy of LA1224-RDB-BSPUG document ?
     Now I have document LSDKUG_Rev21.08.pdf only.
     Thanks.
2,689 次查看
yipingwang
Please refer section 17.5 Synchronizing Linuxptp time with GPS on DU side board in LA1224-RDB-BSPUG.
Let me know if you have further queries.
2,643 次查看
zhujianbin
@yipingwang
2,579 次查看
yipingwang
Please refer to the attachment.
