weak definitions of handlers in Events.c
967 次查看
mentair
is it possible to cause the code generation process to generate __weak definitions of the event handlers in Events.c (in this case for the ARM Compiler)?  I reckon that one would have to modify the component "Events" with the Component Development Environment?  This behaviour would be useful because we use the generated ProcessorExpert Code as a library for several reasons.  Having weak referenes allows to overwrite the handlers one by one in ongoing development, and not being forced to provide stubs for newly generated components not yet in use.
Martin
标记 (1)
884 次查看
vfilip
this is not supported, however I have passed this to developers to consider it.
best regards
Vojtech Filip
Processor Expert Support Team
