Wrong Touch Detection
1,374 次查看
taimurwajad123
Hello All,
We are using TSS 3.1 library and TSI module. Recently we found a problem in our HMI, when interference(EMI) is injected upon HMI electrodes there comes a situaion when one or more electrodes are being permanently detected as pressed untill new startup.
After detailed analysis we found out that when inetreference is injected then there comes a situation when Baseline signal adopts itself to a lesser value than Instant signal and its always detecting as touch because Instant delta remains higher than our electrode threshold and baseline will not adopt itself untill release has been detetcted.
Anyone else faced the same issue? or any leads how we can fix it?
We are using Kinetis K10 uc with Processor expert having 8 electrodes.
1,241 次查看
vicentegomez
Are you setting the autocalibration function? also, there is a manual calibration or hardware recalibration ( I do not remember which one reset the baseline), I recommend you do the calibration after some time.
Also, you can change the N samples to get better results
regards
Vicente Gomez
