Variable frequency signal generation on Kinetis KL25
1,783 次查看
quevedo
I would like to generate a square wave using a FRDM board (Kinetis KL25). However, the LDD timing components only allow me to generate fixed frequencies, i.e., I have to define a fixed frequency in the component properties. There are no options for list of values or frequency interval. Is there any working component for KL25 that allows me to generate a square wave where I can change its frequency with a function?
Thanks in advance
4 回复数
1,385 次查看
Monica
Senior Contributor III
Antonio, was this answer helpful? Please let us know how is the project going.
Regards!
1,385 次查看
vfilip
you can use SetPeriodTicks or SelectInputFrequency methods to change the frequency at run-time.
best regards
Vojtech Filip
Processor Expert Support Team
1,385 次查看
quevedo
What component should I use to generate the square wave with the SetPeriodTicks and SelectInputFrequency methods?
1,385 次查看
Petr_H
You should use the TimerUnit_LDD component.
best regards
Petr Hradsky
