PN7642 C100 - fuse the OTP bit that skips USB-MSC boot
已解决
跳至解决方案
1,725 次查看
UdiO
I have a working target that is based on Pegoda 3 with PN7642 C100.
I'm looking to fuse the OTP bit so that the device will no longer expose the USB mass-storage boot path - permanently force the pin-less download.
I couldn't find the address of this fuse to access it with Segger J-Flash or with direct C code.
Your support is highly appreciated
Udi
标记 (3)
1 解答
1,702 次查看
EduardoZamora
Hello @UdiO
Hope you are doing well.
Please refer to PN7642 SDK > docs > PN76-FW-apiguide. OTP Configuration APIs are described in path: Modules > System Service > SYS OTP Config Interface; there you should find some security features such as Code Read protection and SWD disable.
You could, for example, consider PN76_Sys_OTPConfigs_EnableCRP() API.
Eduardo.
在原帖中查看解决方案
4 回复数
1,681 次查看
UdiO
Thanks Eduardo,
Would it be better to use :
PN76_Sys_OTPConfigs_DwnldReqLessBoot(0);
PN76_Sys_OTPConfigs_LockSettings();
Udi
1,703 次查看
EduardoZamora
Hello @UdiO
Eduardo.
1,681 次查看
UdiO
Thanks Eduardo,
Udi
1,665 次查看
EduardoZamora
PN76_Sys_OTPConfigs_DwnldReqLessBoot is used to configure the value to wait in bootloader if pin-less download is enabled. Refer to PN7642 frequently asked questions, Section 2.7.
PN76_Sys_OTPConfigs_LockSettings LOCKS the configurations done by OTP interfaces and does not allow further modification.
Being OTP (One Time Programmable) API calls, these functions shall be used carefully.
Eduardo.
%3CLINGO-SUB%20id%3D%22lingo-sub-2161906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EPN7642%20C100%20-%20%E7%86%94%E4%B8%9D%E8%B7%B3%E8%BF%87%20USB-MSC%20%E5%90%AF%E5%8A%A8%E7%9A%84%20OTP%20%E4%BD%8D%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2161906%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%3CP%3E%E6%88%91%E6%9C%89%E4%B8%80%E4%B8%AA%E5%9F%BA%E4%BA%8E%20Pegoda%203%20%E5%92%8C%20PN7642%20C100%20%E7%9A%84%E5%B7%A5%E4%BD%9C%E7%9B%AE%E6%A0%87%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%83%B3%E7%86%94%E4%B8%9D%20OTP%20%E4%BD%8D%EF%BC%8C%E8%BF%99%E6%A0%B7%E8%AE%BE%E5%A4%87%E5%B0%B1%E4%B8%8D%E4%BC%9A%E5%86%8D%E6%9A%B4%E9%9C%B2%E4%BA%86%20USB%20%E5%A4%A7%E5%AE%B9%E9%87%8F%E5%AD%98%E5%82%A8%E7%9A%84%E5%90%AF%E5%8A%A8%E8%B7%AF%E5%BE%84%E2%80%94%E2%80%94%E6%B0%B8%E4%B9%85%E5%BC%BA%E5%88%B6%E8%BF%9B%E8%A1%8C%E6%97%A0%E5%AF%86%E7%A0%81%E4%B8%8B%E8%BD%BD%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E6%89%BE%E4%B8%8D%E5%88%B0%E8%BF%99%E4%B8%AA%E7%86%94%E4%B8%9D%E7%9A%84%E5%9C%B0%E5%9D%80%E6%9D%A5%E7%94%A8%20Segger%20J-Flash%20%E6%88%96%E8%80%85%E7%9B%B4%E6%8E%A5%E7%94%A8%20C%20%E4%BB%A3%E7%A0%81%E6%9D%A5%E8%AE%BF%E9%97%AE%E5%AE%83%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CP%3E%E9%9D%9E%E5%B8%B8%E6%84%9F%E8%B0%A2%E6%82%A8%E7%9A%84%E6%94%AF%E6%8C%81%3C%2FP%3E%3CP%3E%E8%B0%A2%E8%B0%A2%EF%BC%81%3C%2FP%3E%3CP%3E%E4%B9%8C%E8%BF%AA%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2163053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7642%20C100%20-%20fuse%20the%20OTP%20bit%20that%20skips%20USB-MSC%20boot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2163053%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%82%A8%E5%A5%BD%EF%BC%8C%3C%2FP%3E%0A%3CP%3EPN76_Sys_OTPConfigs_DwnldReqLessBoot%20%E7%94%A8%E4%BA%8E%E9%85%8D%E7%BD%AE%E5%90%AF%E7%94%A8%E6%97%A0%E5%BC%95%E8%84%9A%E4%B8%8B%E8%BD%BD%E6%97%B6%E5%BC%95%E5%AF%BC%E5%8A%A0%E8%BD%BD%E5%99%A8%E4%B8%AD%E7%9A%84%E7%AD%89%E5%BE%85%E5%80%BC%E3%80%82%E8%AF%B7%E5%8F%82%E9%98%85%3CA%20href%3D%22https%3A%2F%2Fwww.nxp.com%2Fdocs%2Fen%2Fapplication-note%2FAN13936.pdf%22%20target%3D%22_blank%22%20rel%3D%22nofollow%20noopener%20noreferrer%22%3EPN7642%20%E5%B8%B8%E8%A7%81%E9%97%AE%E9%A2%98%3C%2FA%3E%EF%BC%8C%E7%AC%AC%202.7%20%E8%8A%82%E3%80%82%3C%2FP%3E%0A%3CP%3EPN76_Sys_OTPConfigs_LockSettings%20%E9%94%81%E5%AE%9A%20OTP%20%E6%8E%A5%E5%8F%A3%E5%AE%8C%E6%88%90%E7%9A%84%E9%85%8D%E7%BD%AE%EF%BC%8C%E4%B8%8D%E5%85%81%E8%AE%B8%E8%BF%9B%E4%B8%80%E6%AD%A5%E4%BF%AE%E6%94%B9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BD%9C%E4%B8%BA%20OTP%EF%BC%88%E4%B8%80%E6%AC%A1%E6%80%A7%E5%8F%AF%E7%BC%96%E7%A8%8B%EF%BC%89API%20%E8%B0%83%E7%94%A8%EF%BC%8C%E5%BA%94%E8%B0%A8%E6%85%8E%E4%BD%BF%E7%94%A8%E8%BF%99%E4%BA%9B%E5%87%BD%E6%95%B0%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EEduardo%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7642%20C100%20-%20fuse%20the%20OTP%20bit%20that%20skips%20USB-MSC%20boot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162678%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E8%B0%A2%E8%B0%A2%E4%BD%A0%EF%BC%8C%E7%88%B1%E5%BE%B7%E5%8D%8E%E5%A4%9A%E3%80%81%3C%2FP%3E%3CP%3E%E6%98%AF%E5%90%A6%E6%9C%80%E5%A5%BD%E4%BD%BF%E7%94%A8%EF%BC%9A%3CBR%20%2F%3EPN76_Sys_OTPConfigs_DwnldReqLessBoot(0)%3B%3CBR%20%2F%3EPN76_Sys_OTPConfigs_LockSettings()%EF%BC%9B%3C%2FP%3E%3CP%3E%E6%84%9F%E8%B0%A2%3CBR%20%2F%3EUdi%3C%2FP%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7642%20C100%20-%20fuse%20the%20OTP%20bit%20that%20skips%20USB-MSC%20boot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162675%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E8%B0%A2%E8%B0%A2%20Eduardo%EF%BC%8C%3CBR%20%2F%3E%3CBR%20%2F%3E%E4%BD%BF%E7%94%A8%E4%BB%A5%E4%B8%8B%E6%96%B9%E6%B3%95%E6%98%AF%E5%90%A6%E6%9B%B4%E5%A5%BD%EF%BC%9A%3CBR%20%2F%3EPN76_Sys_OTPConfigs_DwnldReqLessBoot(0)%3B%3CBR%20%2F%3EPN76_Sys_OTPConfigs_LockSettings()%3B%3CBR%20%2F%3E%3CBR%20%2F%3E%E8%B0%A2%E8%B0%A2%3CBR%20%2F%3EUdi%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2162323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%20translate%3D%22no%22%3ERe%3A%20PN7642%20C100%20-%20fuse%20the%20OTP%20bit%20that%20skips%20USB-MSC%20boot%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2162323%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E4%BD%A0%E5%A5%BD%3CA%20href%3D%22https%3A%2F%2Fcommunity.nxp.com%2Ft5%2Fuser%2Fviewprofilepage%2Fuser-id%2F254344%22%20target%3D%22_blank%22%3E%40UdiO%3C%2FA%3E%3C%2FP%3E%0A%3CP%3E%E5%B8%8C%E6%9C%9B%E4%BD%A0%E4%B8%80%E5%88%87%E9%A1%BA%E5%88%A9%E3%80%82%3C%2FP%3E%0A%3CP%3E%E8%AF%B7%E5%8F%82%E9%98%85%20PN7642%20SDK%26gt%3B%20docs%26gt%3B%20PN76-FW-apiguide%E3%80%82OTP%20%E9%85%8D%E7%BD%AE%20API%20%E5%9C%A8%E8%B7%AF%E5%BE%84%E4%B8%AD%E6%8F%8F%E8%BF%B0%EF%BC%9A%E6%A8%A1%E5%9D%97%20%26gt%3B%20%E7%B3%BB%E7%BB%9F%E6%9C%8D%E5%8A%A1%20%26gt%3B%20SYS%20OTP%20%E9%85%8D%E7%BD%AE%E6%8E%A5%E5%8F%A3%EF%BC%9B%E5%9C%A8%E9%82%A3%E9%87%8C%E4%BD%A0%E5%BA%94%E8%AF%A5%E5%8F%AF%E4%BB%A5%E6%89%BE%E5%88%B0%E4%B8%80%E4%BA%9B%E7%BD%91%E7%BB%9C%E5%AE%89%E5%85%A8%E5%8A%9F%E8%83%BD%EF%BC%8C%E4%BE%8B%E5%A6%82%E4%BB%A3%E7%A0%81%E8%AF%BB%E5%8F%96%E4%BF%9D%E6%8A%A4%E5%92%8C%20SWD%20%E7%A6%81%E7%94%A8%E3%80%82%3C%2FP%3E%0A%3CP%3E%E4%BE%8B%E5%A6%82%EF%BC%8C%E6%82%A8%E5%8F%AF%E4%BB%A5%E8%80%83%E8%99%91%E4%BD%BF%E7%94%A8%20PN76_Sys_OTPConfigs_EnableCRP()%20API%E3%80%82%3C%2FP%3E%0A%3CP%3E%3CBR%20%2F%3EEduardo%E3%80%82%3C%2FP%3E%3C%2FLINGO-BODY%3E
