How to view "Target CPU" in CW10.4
887 次查看
rabbit
I just move from CW10.2 to CW10.4.
In CW10.2 PE, I can view "Target CPU" as a map which display all the pins. This is very useful for hardware debugging.
But I can't find this feature in CW10.4, I believe this should be available in CW10.4.
Sam
814 次查看
ZhangJennie
not sure if i understand the questions.
in CW10.4 IDE menu, "show view", "others", under "processor expert", thre is "processor " that can show MCU all pins.
and there i "Memory map " that can show memory allocation.
815 次查看
ZhangJennie
