I can't find the processor expert in S32DS.3.3 with SDK S32K1XX RTM 4.0.1
I can't find it between top tags "Help", "Window", "Run", etc; neither in "Select a wizard" and i can't find "Generate processor expert code" in "Proyect" tag.
Does the S32 Configuration tool replace the processor expert?
Thanks.
Solved! Go to Solution.
yes, that's correct. You can take a look at the quick start guide, section "2.6 Graphical Configuration of Drivers":
c:\NXP\S32DS.3.4\S32DS\software\S32SDK_S32K1XX_RTM_4.0.1\doc\S32SDKQSG.pdf
Lukas
Lukas
Hi Lukas,
First of all, Thank you very much for your answer.
That replacement is not given in RTM 4.0.0? I mean, could I use the processor expert in RTM 4.0.0?
In this case, how can I download it? I tried to download it here:
but as you can see, "S32 SDK for S321Kxx RTM 4.0.0" is the title but I can only download version "RTM_4.0.1".
Thanks again,
Guille.
