How to Handle Clock Rate List for SPIMaster_LDD
975 次查看
Vagni
I am using SPIMaster_LDD embedded component for my project with CodeWarrior 10.2 and Processor Expert 5.3 on a Kinetis K10DX256VLH7 mcu.
SPIMaster_LDD is set with polling mode and one attribute set.
I defined a list of clock rates, because in my application I need to switch in run-time from a clock rate to another, (mainly from a low clock rate to a higher one).
I cannot see what is the right component method for switching in run-time among the clock rates of my list.
Can you please tell me how can I do that clock rate switch?
Thank you!
805 次查看
BlackNight
I have used the SynchroMaster component which is easier to use.
There you can set up as well a list of clock rates, and then switch it with SetBaudRateMode().
That worked very well for me (e.g. with SD card interface which needs different speed modes.
